Browse Forums Pools & Spas Re: Distance between pool, house and boundary 4Feb 05, 2017 12:02 pm Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 5Feb 05, 2017 1:56 pm If they have less an 1m to waterline it would of needed a development application . You would have been notified . If it was complying development you wouldn't be notified .notified but pool needs to be 1m off boundary. Re: Distance between pool, house and boundary 6Feb 05, 2017 1:59 pm wheeliworks If they have less an 1m to waterline it would of needed a development application . You would have been notified . If it was complying development you wouldn't be notified .notified but pool needs to be 1m off boundary. The strange thing is that we haven't been notified, at all. Thank you. This is very interesting. Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 7Feb 05, 2017 2:13 pm If it is still being built they will have a sign out the front of their house with builder and certifier details . You should ring the certifier . If it is complete you can ring the council' Re: Distance between pool, house and boundary 8Mar 12, 2017 6:20 am xyz I am a little bit worrying about my neighbours who put their pool quite close to the boundary. 80cm to the to-be water line. Blacktown council (NSW). Is it legal? I'll take a guess here. If you are able to measure that it's 80cm, then they might be allowing 15-20cm concrete wall and tiling. It's only a guess Good luck Found the answer. The recommended distance is .... 1 6052 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17283 ask the surveyor for clarification would be the logical approach 1 20238 |
