Browse Forums Building A New House Re: Metricon Liberty 45 (Turramurra) 85Jan 25, 2017 8:49 am NthHome vuster Looks like it's gonna be a great house. You sure do sound like you love your AV. Your projector is top of the range, I'm getting an Epson as well but it's one model lower than yours. I had a look at your sitting room/cinema electrical plans and I had a couple of atmos speakers in the ceiling close to the front and also rear speakers. After further consultation with "The Big Picture People" regarding best practice for an Atmos system, they said the atmos in ceiling speakers should be positioned closer to where you would sit.. They also said rear speakers would be best at the sides instead of the back. I raised a construction variation with Metricon to cancel the supply and installation of the speakers and then ran a few more speaker wires to the recommended positions. It's not clear in the electrical plans but the atmos speakers (wiring) are above the to be lounge position - the end closest to the garage. The projector will sit in the garage and the lenses will peek through a hole in the wall , much like in the cinemas. This will give me a little bit more flexibility with the screen size / and look less bulky in the home theatre room. I get your comment re rear speakers , I'm going for 7.1.4 setup which has two at rear , two at sides, three front (includes Ctr) and a sub. Is that what your going for? Did they still say rear are no good? Ps who are the big picture people ? "The Big Picture" people are a home theatre retailer which Metricon use as a supplier. I'm going for the 5.1.2 which would be layed out as follows: http://www.demo-world.eu/wp-content/upl ... -setup.jpg I did consider your configuration but I thought the size of the room was a bit small for that. Re: Metricon Liberty 45 (Turramurra) 86Jan 25, 2017 11:31 pm Are they in Melb? In Sydney no one ever mentioned they have a home theatre supplier Re: Metricon Liberty 45 (Turramurra) 87Jan 25, 2017 11:32 pm Renman NthHome sinbox Hey @NthHome...nice setup you have planned there. Have you considered security cameras into the equation? Security cameras are planned but still haven't decided . I have 6 network points for cameras . 4 external and 2 internal . Still trying to find a good setup that won't cost a bomb Are you looking at Webcam or CCTV options? No idea at this point. All I've done so Far is provision 6 cameras points with cat6 for future poe devices Re: Metricon Liberty 45 (Turramurra) 88Jan 25, 2017 11:37 pm NthHome Are they in Melb? In Sydney no one ever mentioned they have a home theatre supplier Yeah they are in Melb. Re: Metricon Liberty 45 (Turramurra) 89Jan 27, 2017 2:33 pm NthHome Renman NthHome [quote="sinbox"]Hey @NthHome...nice setup you have planned there. Have you considered security cameras into the equation? Security cameras are planned but still haven't decided . I have 6 network points for cameras . 4 external and 2 internal . Still trying to find a good setup that won't cost a bomb Are you looking at Webcam or CCTV options? No idea at this point. All I've done so Far is provision 6 cameras points with cat6 for future poe devices [/quote] The key thing is that you have provisioned for the POE ports...which is great. I'm going for 8 -10 Hikvision camera + NVR myself. Still undecided on the exact models, but will start researching as soon as we get the build started. Have you thought about where the NVR may go? I have provisioned a couple of points in a bedroom closet just in case I decide to place the NVR there. Did Metricon charge you extra for providing a hole in the garage wall? I had requested this feature myself as the garage would have made an ideal space for my AV rack, but Porter Davis have said it can't be done due to structural reasons. I'll have to try my luck with the Site supervisor directly, else the AV closet is going to be spread across the theatre and under stairs area for me... Re: Metricon Liberty 45 (Turramurra) 90Jan 27, 2017 4:30 pm sinbox NthHome Renman [quote="NthHome"][quote="sinbox"]Hey @NthHome...nice setup you have planned there. Have you considered security cameras into the equation? Security cameras are planned but still haven't decided . I have 6 network points for cameras . 4 external and 2 internal . Still trying to find a good setup that won't cost a bomb Are you looking at Webcam or CCTV options? No idea at this point. All I've done so Far is provision 6 cameras points with cat6 for future poe devices [/quote] The key thing is that you have provisioned for the POE ports...which is great. I'm going for 8 -10 Hikvision camera + NVR myself. Still undecided on the exact models, but will start researching as soon as we get the build started. Have you thought about where the NVR may go? I have provisioned a couple of points in a bedroom closet just in case I decide to place the NVR there. Did Metricon charge you extra for providing a hole in the garage wall? I had requested this feature myself as the garage would have made an ideal space for my AV rack, but Porter Davis have said it can't be done due to structural reasons. I'll have to try my luck with the Site supervisor directly, else the AV closet is going to be spread across the theatre and under stairs area for me... [/quote] The hole in the wall for projector is a site mgr thing Av rack - avoid the garage due to lack of air con. Your amps are likely to over heat. I had to change my plan cause of this. Just put network gear in garage if you have to. That's what I'm doing now. Nvr- all the Camera network cables will return to linen cupboard upstairs where I'll have a poe switch and nvr . From the cupboard it will also connect to the main house network(single cat6 to garage) What type of nvr I got no idea! Hkvision ??? Re: Metricon Liberty 45 (Turramurra) 91Jan 27, 2017 5:17 pm NthHome sinbox NthHome [quote="Renman"][quote="NthHome"][quote="sinbox"]Hey @NthHome...nice setup you have planned there. Have you considered security cameras into the equation? Security cameras are planned but still haven't decided . I have 6 network points for cameras . 4 external and 2 internal . Still trying to find a good setup that won't cost a bomb Are you looking at Webcam or CCTV options? No idea at this point. All I've done so Far is provision 6 cameras points with cat6 for future poe devices [/quote] The key thing is that you have provisioned for the POE ports...which is great. I'm going for 8 -10 Hikvision camera + NVR myself. Still undecided on the exact models, but will start researching as soon as we get the build started. Have you thought about where the NVR may go? I have provisioned a couple of points in a bedroom closet just in case I decide to place the NVR there. Did Metricon charge you extra for providing a hole in the garage wall? I had requested this feature myself as the garage would have made an ideal space for my AV rack, but Porter Davis have said it can't be done due to structural reasons. I'll have to try my luck with the Site supervisor directly, else the AV closet is going to be spread across the theatre and under stairs area for me... [/quote] The hole in the wall for projector is a site mgr thing Av rack - avoid the garage due to lack of air con. Your amps are likely to over heat. I had to change my plan cause of this. Just put network gear in garage if you have to. That's what I'm doing now. Nvr- all the Camera network cables will return to linen cupboard upstairs where I'll have a poe switch and nvr . From the cupboard it will also connect to the main house network(single cat6 to garage) What type of nvr I got no idea! Hkvision ??? [/quote] Just a quick note - If you are going to do wireless network, run a few more Cat6 POE for your AP's. also not that if you have acoustic insulation batts in the internal walls you are going to lose between 2-3db. Re: Metricon Liberty 45 (Turramurra) 92Jan 27, 2017 5:25 pm Renman NthHome sinbox [quote="NthHome"][quote="Renman"][quote="NthHome"][quote="sinbox"]Hey @NthHome...nice setup you have planned there. Have you considered security cameras into the equation? Security cameras are planned but still haven't decided . I have 6 network points for cameras . 4 external and 2 internal . Still trying to find a good setup that won't cost a bomb Are you looking at Webcam or CCTV options? No idea at this point. All I've done so Far is provision 6 cameras points with cat6 for future poe devices [/quote] The key thing is that you have provisioned for the POE ports...which is great. I'm going for 8 -10 Hikvision camera + NVR myself. Still undecided on the exact models, but will start researching as soon as we get the build started. Have you thought about where the NVR may go? I have provisioned a couple of points in a bedroom closet just in case I decide to place the NVR there. Did Metricon charge you extra for providing a hole in the garage wall? I had requested this feature myself as the garage would have made an ideal space for my AV rack, but Porter Davis have said it can't be done due to structural reasons. I'll have to try my luck with the Site supervisor directly, else the AV closet is going to be spread across the theatre and under stairs area for me... [/quote] The hole in the wall for projector is a site mgr thing Av rack - avoid the garage due to lack of air con. Your amps are likely to over heat. I had to change my plan cause of this. Just put network gear in garage if you have to. That's what I'm doing now. Nvr- all the Camera network cables will return to linen cupboard upstairs where I'll have a poe switch and nvr . From the cupboard it will also connect to the main house network(single cat6 to garage) What type of nvr I got no idea! Hkvision ??? [/quote] Just a quick note - If you are going to do wireless network, run a few more Cat6 POE for your AP's. also not that if you have acoustic insulation batts in the internal walls you are going to lose between 2-3db. [/quote] Why multiple cat6 for poe? Cheers Re: Metricon Liberty 45 (Turramurra) 93Jan 27, 2017 10:54 pm Saves you running power and then a separate Cat6 for data. Is that what you mean? Re: Metricon Liberty 45 (Turramurra) 94Jan 28, 2017 6:29 am Renman Saves you running power and then a separate Cat6 for data. Is that what you mean? Re: Metricon Liberty 45 (Turramurra) 95Jan 28, 2017 9:56 pm https://www.facebook.com/daniel.anker.1 ... 188410372/ you may have to add me as a friend to watch but its worth it!!! Re: Metricon Liberty 45 (Turramurra) 96Jan 28, 2017 10:06 pm NthHome Renman Saves you running power and then a separate Cat6 for data. Is that what you mean? I think you miss read my post. My recommendation for you to run more was for the Wireless APs and not for the camera. Re: Metricon Liberty 45 (Turramurra) 98Feb 11, 2017 10:20 am Re: Metricon Liberty 45 (Turramurra) 99Feb 11, 2017 10:20 am Renman NthHome Renman Saves you running power and then a separate Cat6 for data. Is that what you mean? I think you miss read my post. My recommendation for you to run more was for the Wireless APs and not for the camera. I thought I only needed one per AP? Metricon Liberty 45 (Turramurra) 100Feb 11, 2017 11:59 am NthHome Renman NthHome [quote="Renman"]Saves you running power and then a separate Cat6 for data. Is that what you mean? I think you miss read my post. My recommendation for you to run more was for the Wireless APs and not for the camera. I thought I only needed one per AP? [/quote] You will need a couple of AP around the house. We are looking at 4 for our place. To make sure the heat maps covers 95-100% of the house. The other Cat6 will be for the PoE web cameras. Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12929 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9799 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19828 |
