Browse Forums Building A New House Re: Dream Metricon Glendale 38 (Sydney)! 3847Dec 23, 2016 1:58 pm Option 2 is good but would you need to do the taps in the other bathrooms to match? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Dream Metricon Glendale 38 (Sydney)! 3848Dec 23, 2016 2:01 pm Quirmeball1280 Option 2 is good but would you need to do the taps in the other bathrooms to match? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Not really as the taps are different in the other bathrooms. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 3849Dec 23, 2016 10:10 pm Gosh, what a dilemma. Even though that tap looks pretty awesome, I'd go with changing the basins, only because, like franky said, do all your other taps in the bathroom match? Is this bathroom the only bathroom that has the vessel basins? Re: Dream Metricon Glendale 38 (Sydney)! 3850Dec 23, 2016 10:29 pm Phoenix37 Gosh, what a dilemma. Even though that tap looks pretty awesome, I'd go with changing the basins, only because, like franky said, do all your other taps in the bathroom match? Is this bathroom the only bathroom that has the vessel basins? Hi P37, Yeah only the ensuite has the vessel and the wall mounted mixers. The other bathrooms have the mixer on the basin. I think option 1 with changing the basin might be an easier solution.. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 3851Dec 23, 2016 11:58 pm I like basin option B with your existing mixer. Reason being that it has higher sides so less splash and if you ever need to fill up your basin it will hold more water. Otherwise keep existing basin and go with the grooved teknobilii tapware. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Dream Metricon Glendale 38 (Sydney)! 3853Dec 24, 2016 8:11 am Thanks for the contribution everyone! We went into the Reece bathroom life centre and geez they have so many cool stuff in there. Too bad M studio doesn't carry all the full range from Reece... this is kind of annoying as there are so many other options to all of M clients. So we checked out the Teknobili cascade mixer and my gosh it looked awesome!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now for the bad news. I noticed the distance between the water sprout and mixer handle for the Teknobili is 10mm less than our current mixer set. This means most likely they are not compatible...... I'm waiting for our SM to verify this.... Then we checked out the basins we have identified in my earlier post and found the Laufen Paloma basin the best looking one. Laufen Paloma: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The other basin options: AXA H10: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also found another type of mixer set with the right configuration and noticed the mixer handle pointed upwards....this means it won't interfere with out basin and thus we use it with our original vessel basin. Let's wait what our SM says about changing to this mixer. Sussex Scala mixer set: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thoughts? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 3854Dec 24, 2016 12:11 pm I like the first basin option still looks pretty funky, but that other spout with mixer pointing upwards looks good and you could still keep your chosen basin Re: Dream Metricon Glendale 38 (Sydney)! 3855Dec 24, 2016 1:52 pm I like the look of the Laufen Paloma basin ------- Metricon Aria https://ourlittlearia.wordpress.com/ Re: Dream Metricon Glendale 38 (Sydney)! 3856Dec 24, 2016 6:03 pm Hi Orph, thinking outside the box, can your original tap be fitted with the handle pointing up? There may be a way to do that, or even an accessory you can buy to reverse it? If not, option B would be my choice if that's still possible. On a similar theme, check the water flow rate in the tap for your island be bench. We've found the flow rate is poor compared to the tap in the butlers pantry. M are investigating but I'm hearing this seems to be a common problem. Not sure what is causing it though. Re: Dream Metricon Glendale 38 (Sydney)! 3857Dec 24, 2016 6:32 pm VistaDream Hi Orph, thinking outside the box, can your original tap be fitted with the handle pointing up? There may be a way to do that, or even an accessory you can buy to reverse it? If not, option B would be my choice if that's still possible. On a similar theme, check the water flow rate in the tap for your island be bench. We've found the flow rate is poor compared to the tap in the butlers pantry. M are investigating but I'm hearing this seems to be a common problem. Not sure what is causing it though. Thanks Vista, I think we can't invert the handle as the hot/cold labels are upside down. We would need to change the whole tap with the proper one which is design with the handle pointing up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 3858Dec 24, 2016 7:20 pm We built with eden brae 5 years ago. Once all the tiling was done. i noticed that *all* niches' were smaller than whats depicted on the plans. Our SM offered to buy us new canisters to hold the shampoo etc (!!) - We stood firm and said that we didn't want anything else but to have our niches' as per the plans. They had no choice but to rectify as per the plans and contract. As they say in building - you have to pick your battles - so Orph you have to decide if you even want to entertain the options presented by M. I know the proper rectification will include, re-tiling, waterproof etc = delays. But its your dream house and you will have to live with this for a while... Re: Dream Metricon Glendale 38 (Sydney)! 3859Dec 25, 2016 7:56 am Hi orph, Sussex will customise nearly all of their tapwear. So if you find one you like but mixer points down, they can change it. C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Dream Metricon Glendale 38 (Sydney)! 3860Dec 26, 2016 10:22 pm Thanks everyone for the inputs, will update you on the outcome...let's hope it's positive news. In other news, boxing day shopping we found our laundry appliances....Samsung washing and dryer twin units. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1. Crystal Blue door 11kg with LED display washing machine Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. Crystal Blue door 9kg heat pump dryer machine (no venting required) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Has anyone purchased or using these yet? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10715 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8152 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17321 |
