Browse Forums Landscape & Garden Design Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 131Feb 27, 2017 2:52 pm wow... wrexter.. you're a one man builder with great architectural skills... I wish you're my neighbor ... btw.. quick one.. i decided to go on fully concrete slab extended from my alfresco ( i don't have side raised garden beds).. I don't see much of a people doing this. they usually go for decking like you did.. anything i should be worry about .... Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 133Mar 30, 2017 10:49 pm Mate it looks sensational, hope my backyard turns out 1/2 as good as this! Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 134Aug 01, 2017 10:10 am Hey Wrexter, love this thread! Have read it countless times during the course of my build. I would love to do some rendered brick wall gardens like you did and was wondering if you could provide some dimensions for your wall or any finer details? I am thinking I will also go with the Gro Wall 4 as well. Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 135Aug 06, 2017 7:01 pm Has anyone else attempted anything similar? I am wondering how I would discretely do the retic to the gro wall in this set up, I obviously want to plan everything out first before getting started... Re: WREXTER'S REAR LANDSCAPING JOURNEY - Update Photos 136Oct 07, 2017 8:32 pm Hi wrexter. Hoping you might be able to explain a little more about your irrigation. 1. What's the loop and manual valve do before your solenoids. 2. Where's the x core controller located? Assume you also have some sensor attached? 3. How did you calculate the flow within each zone. I assume only one zone at a time? 4 would you mind sharing the parts list you got especially the hardware used from 20mm PVC to flex head you used on the pop-ups and other spray heads? 5 Lastly. The lighting is controlled via switches or pv sensor? Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8494 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7301 |
