Browse Forums Building Standards; Getting It Right! Re: Charged storm water system 2Nov 27, 2016 11:55 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Charged storm water system 5Nov 27, 2016 4:20 pm Looks like an IO. It will have to remain accessible. Where does the charged pipe drain to? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Charged storm water system 8Nov 27, 2016 9:46 pm shanil86 On the storm water plan it goes back to the rainwater tank. Ok, I have the complete picture now. It is an Inspection Outlet (IO) but it seems to be a very strange place to put it and an archaic sub standard way of doing things. From memory, you are in...Melbourne metro? Have they fitted leaf diverters to every downpipe being diverted? It is important to keep organic matter out of wet systems. Charged systems build up crud which can turn the retained water anaerobic because even during heavy rain, the water lacks the velocity up the vertical riser to flush the subsurface pipe. A wet system also won't flush through an IO due to the top of the IO being higher than the pipe. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Charged storm water system 10Nov 27, 2016 10:38 pm The IO is next to useless unfortunately. You really need a sediment trap on a wet system. If you browse through Eco Living rainwater harvesting threads, you will find a diagram of a simple but very effective DIY sediment trap in several threads. The thread below has a diagram at the bottom of the first (and only) reply. viewtopic.php?f=35&t=85013 You mentioned that there were 2 pipes diverted to the tank. How many downpipes are diverted to those 2 pipes? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19865 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7986 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6970 |
