Ours costed $742 for Urbane wall faced close coupled toilet suite with soft closing seat.
Browse Forums Building A New House Re: Boutique Homes 2902Nov 23, 2016 10:25 pm --------------------------------------------- Building a St. Tropez 25 - Boutique Homes Aurora Estate Wollert - Victoria Re: Boutique Homes 2907Nov 24, 2016 10:53 am newbietobuilding That's great to hear as I was planning to go with them too but my other half doesn't think it's necessary but this helps make our decision! I highly recommend an independent inspector. You just never know what hasn't been done properly. A couple of thousand now in inspections could save you a lot of heart ache months after you move in. Re: Boutique Homes 2908Nov 24, 2016 11:40 am measure We received our slab/frame independent inspection report this week and whilst there wasn't a lot of defects, the defects listed seem rather large jobs to rectify. They are as follows. - Large amounts of slab over pour which will require engineering to come up with a plan to rectify without damaging the slab. - The site cut has been advised as very poor in general with the fall of the land falling towards the slab. This means that water can pool against the slab and run under the house. This could cause major issues in the future. - A few frame issues with the frame over hanging the slab as the slab in some sections has been poured incorrectly. - Intersecting sections of frame walls are not actually connected which means that future movement and plaster cracking is very likely - Lots of areas where the slab is not level. There are a few sections where the fall and rise of the slab is way above allowed tolerances meaning to fix they will have to grind back sections. - Areas of the roof trusses were not connected with brackets to the load bearing walls meaning those trusses could move. - There are non loading bearing walls which have been converted to load bearing using blocking. Overall some pretty concerning points that I am glad the inspection picked up. We have formally requested Boutique to fix these defects. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's a worry. Dunno how they're gonna fix that stuff without pulling down the frame and breaking up the slab. Did darbecca do an inspection prior to the slab being poured? I hope the rectification (whatever form it takes) goes well for you. Re: Boutique Homes 2909Nov 24, 2016 12:07 pm Wow, they are concerning defects. Very glad we have completed our own cut and fill privately. Also engaging Darbecca, but never questioned needing an inspector. No confidence without one! Building the Barcelona with Boutique Homes - construction due to commence approx. February 2017 My building blog: http://www.firstbornhouse.wordpress.com Re: Boutique Homes 2910Nov 24, 2016 12:54 pm emerthis That's a worry. Dunno how they're gonna fix that stuff without pulling down the frame and breaking up the slab. Did darbecca do an inspection prior to the slab being poured? I hope the rectification (whatever form it takes) goes well for you. I had booked a pre pour inspection and had advised Boutique however they didn't pass it on to the supervisor or booked the slab pour without knowing. An angry email and phone call to Boutique's Client Liason manager followed. They have been a lot more forthcoming and responsive since. Re: Boutique Homes 2911Nov 24, 2016 6:13 pm measure We received our slab/frame independent inspection report this week and whilst there wasn't a lot of defects, the defects listed seem rather large jobs to rectify. They are as follows. - Large amounts of slab over pour which will require engineering to come up with a plan to rectify without damaging the slab. - The site cut has been advised as very poor in general with the fall of the land falling towards the slab. This means that water can pool against the slab and run under the house. This could cause major issues in the future. - A few frame issues with the frame over hanging the slab as the slab in some sections has been poured incorrectly. - Intersecting sections of frame walls are not actually connected which means that future movement and plaster cracking is very likely - Lots of areas where the slab is not level. There are a few sections where the fall and rise of the slab is way above allowed tolerances meaning to fix they will have to grind back sections. - Areas of the roof trusses were not connected with brackets to the load bearing walls meaning those trusses could move. - There are non loading bearing walls which have been converted to load bearing using blocking. Overall some pretty concerning points that I am glad the inspection picked up. We have formally requested Boutique to fix these defects. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Don't know if it helps but all your items listed are common items. The slab over pour gets jack hammered off, the site clean they won't do till later on, the timber frame u would be surprised but it's a quick fix, all they do is add additional timber to ensure all frame joined (same thing happened with ours) unlevel concrete they level it either during tiling or use fill under carpet. As long as frame is rectified before plaster you should be fine Re: Boutique Homes 2912Nov 26, 2016 4:14 pm We have great news! Our land settles Dec 6! So 2017 we will start building... For a single storey, estimate build time? Understanding their are always issues. We are eager. Everything signed Obviously nothing will probably happen until feb. Re: Boutique Homes 2913Nov 26, 2016 5:31 pm Jadeypox We have great news! Our land settles Dec 6! So 2017 we will start building... For a single storey, estimate build time? Understanding their are always issues. We are eager. Everything signed Obviously nothing will probably happen until feb. Exciting times ahead! Our home took 4 months to build... https://letsbuildwithboutique.wordpress.com Re: Boutique Homes 2914Nov 26, 2016 9:37 pm Jadeypox We have great news! Our land settles Dec 6! So 2017 we will start building... For a single storey, estimate build time? Understanding their are always issues. We are eager. Everything signed Obviously nothing will probably happen until feb. It takes 2 months for the permit and other stuff before they can start clear your land and build plus holiday break...goodluck Jadeypox...give or take after they put the slab around 5 to 6 months --------------------------------------------- Building a St. Tropez 25 - Boutique Homes Aurora Estate Wollert - Victoria Re: Boutique Homes 2915Nov 26, 2016 9:40 pm --------------------------------------------- Building a St. Tropez 25 - Boutique Homes Aurora Estate Wollert - Victoria Re: Boutique Homes 2916Nov 27, 2016 10:06 am Thanks for all the responses! Argh I wish permits will magically be set by Jan in a miraculous way hahah! I guess no point booking our intended June euro holiday to see family I would love to get the house done and not rushed (expecting lots of hiccups) by then. Re: Boutique Homes 2917Nov 27, 2016 12:24 pm Thanks for all the responses! Argh I wish permits will magically be set by Jan in a miraculous way hahah! I guess no point booking our intended June euro holiday to see family I would love to get the house done and not rushed (expecting lots of hiccups) by then. Re: Boutique Homes 2918Nov 28, 2016 10:49 am Jadeypox We have great news! Our land settles Dec 6! So 2017 we will start building... For a single storey, estimate build time? Understanding their are always issues. We are eager. Everything signed Obviously nothing will probably happen until feb. Ours took 8 months 3 weeks and 2 days. Single storey 36sq home Re: Boutique Homes 2919Nov 28, 2016 10:52 am Ozden86 Jadeypox We have great news! Our land settles Dec 6! So 2017 we will start building... For a single storey, estimate build time? Understanding their are always issues. We are eager. Everything signed Obviously nothing will probably happen until feb. Ours took 8 months 3 weeks and 2 days. Single storey 36sq home Looking at the Metricon house already roofed and walled up around the corner from us at about 1 month of visual development... I feel like I am going to be very impatient hahaha. I do want a good build though. Thanks for the time frame! Re: Boutique Homes 2920Nov 28, 2016 8:22 pm Stage 2 : Frame and roof trusses is up. It starts to look like a home now. Timeline : (nearing 2 years now) 1. Feb 2015 - Off the plan downpayment for the land. 2. May 2016 - Estate developed. 3. June 2016 - Land settlement. 4. Sept 2016 - Developer approval. 5. Oct 2016 - Site scraping. 6. Nov 2016 - Slab and Frame. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building a St Tropez 25 --------------------------------------------- Building a St. Tropez 25 - Boutique Homes Aurora Estate Wollert - Victoria 10 15860 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 76387 |
