Browse Forums Eco Living Re: Rainwater catchment 2Nov 17, 2016 6:03 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Rainwater catchment 4Nov 17, 2016 10:03 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Rainwater catchment 5Nov 17, 2016 10:54 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater catchment 7Nov 17, 2016 11:59 am Building a Fairmont Custom in Seaford Meadows Our Build Thread Re: Rainwater catchment 9Nov 17, 2016 4:14 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater catchment 10Nov 17, 2016 8:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater catchment 12Nov 18, 2016 10:43 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater catchment 14Nov 18, 2016 7:40 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater catchment 15Nov 21, 2016 10:32 am I contacted my builder said we don't want PVC downpipes as it is cheaper than colorbond one. And i told them, if all it does it getting a water catchment point for us then we don't want it to be installed. I got the reply a few minutes ago saying that since we already asked for it and signed it, we must have it. I will just go to consumer affairs. Thanks Re: Rainwater catchment 16Nov 21, 2016 8:18 pm If you have a standard rainwater harvesting system, you will need pvc downpipes but there would usually only be a couple of downpipes affected. Contracturally, they have you over a barrel. The big problem is that the wording is vague and you don't know what you are actually getting or if you even need what they intend doing. It should have been properly worded and explained to you. Answer needed I asked what we are being supplied for the $880 we paid and this is the reply from the builder. They say we are paying for building variation we made. This is the exact reply. As per variation you are paying for 100mm diameter PVC downpipes in lieu of Colorbond plus an additional run for approximately 5 meters to a point of discharge that you will be able to connect your future tank to. The way I read the builder's discombobulated reply is... 1. You are almost certainly paying for a variation. This is usually a $500 charge. Ouch!!! 2. You are having all of your Colorbond downpipes replaced with cheaper PVC downpipes. 3. I can only assume that the "5 metres to a point of discharge that you will be able to connect your future tank to" is a connection to the stormwater from the proposed tank's overflow connection. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19880 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8655 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31467 |
