Browse Forums General Discussion 1 May 17, 2004 12:05 am Hi,
Hope someone can give me a solution to this problem I formed up a 50sqm slab for our patio, did all the levels right, compacted gravel then sand, chaired up the mesh and so on and so forth. The day of the concrete truck arrived, it was supposed to be at 12pm. I had a concretor who was going to direct the screeding and finishing. The truck didn't arrive for 2and a half hours and the concretor had to go to another job. I was left to do the job which wasn't a big issue. The cement came off the truck, and not being a concretor, it looked alright to me, and the truck driver seemed happy. Got all the cement in the form in about 15 minutes and one of my mates and I started screeding. About 20 minutes later, I realised the concrete was already going off. I put as much water on it as I thought was safe and kept going. We nearly killed ourselves getting it as level as possible then we got the wooden trowels out started trying to bring the slurry to the surface, but to no avail. This was around an hour and 15 mintues after the truck left! The concretor returned and he went off his tree about how dry the crete was. We spent the next 2 hours trying to salvage some finish in the slab. What I am left with isn't pretty to say the least. Any suggestions on how I can rescue the suface finish? I also think I am going to have problems with concrete dust with the amount of water we used to bring up any slurry... Thanks in advance.. Re: concrete woes 3Sep 29, 2004 9:41 am HI
I had a similar problem (late truck, helper had to go, extra hot day) and ended up with very wavey surface with screed/trowel marks; at least it was non-slip. So far I have used a conc. surface grimder to smooth/level surface, but still not great, next I plan to cover with something that will fill in the hollows. Regular concrete cover/paints are a maximum 5mm thick, but I need about 30mm thick. There is only one product I have found that will fill (as opposed to just cover) and is self leveling, it is made by REBOUND ACE, the company that does tennis courts. They have the details on their web site. I have not tried it yet as there are other more urgent projects - of course. Good luck Re: concrete woes 5Nov 04, 2004 9:20 pm You poor bloke! My heart goes out to you really!! I'm just about to have a go at my first concreting project, a 9sqm slab for a shed, and i value your experience in that others can learn from it. Thanks for sharing your dilemma.
I would have been lefting holding a trowel in one hand and a gun in the other after that experience. Do you have any other tips for a first timer and a mate doing a slab? Good luck with future projects by the way. Re: concrete woes 7Apr 28, 2005 11:52 am Or try tiles. It's amazing what tiles look like on a patio. Choose a non-slip tile and use plenty of glue to help over come any unevenness in the concrete. It'll look a million bucks. Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11020 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3165 |
