Browse Forums Flooring & Floor Covering Re: Loose lay vinyl planks 4Oct 13, 2016 11:25 am Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 6Oct 13, 2016 2:24 pm Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 8Oct 13, 2016 2:29 pm Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 12Nov 01, 2016 8:28 pm Our Karndean got installed on Saturday!!! I love how it looks (pic was taken through glass so not the best image.) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had all our flooring installed via our builder - the Karndean portion was expensive. I won't lie, it was just under $10k. You can see my thread for the floorplan (the vinyl is clearly marked on it.) It was a teensy bit cheaper to do it independent of our builder after handover but we thought we'd rather pay that little bit extra (we're talking a few hundred dollars here) to get everything done at once - that way if the flooring contractor scuffed walls (which he did) it's all covered under the builders insurance and any faults/problems get fixed without us having to pay extra or do anything ourselves. Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 13Nov 02, 2016 10:39 am SallyS Our Karndean got installed on Saturday!!! I love how it looks (pic was taken through glass so not the best image.) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had all our flooring installed via our builder - the Karndean portion was expensive. I won't lie, it was just under $10k. You can see my thread for the floorplan (the vinyl is clearly marked on it.) It was a teensy bit cheaper to do it independent of our builder after handover but we thought we'd rather pay that little bit extra (we're talking a few hundred dollars here) to get everything done at once - that way if the flooring contractor scuffed walls (which he did) it's all covered under the builders insurance and any faults/problems get fixed without us having to pay extra or do anything ourselves. That looks gorgeous!! Yes o asked for a quote from my builder but they don't do vinyl anymore. I dont believe they will let me free issue so that they can fit it. Just checked out carpet court and they are charging $100/sqm supply and laid bit not including what ever floor prep that may or may not be required Does that sound about right? Re: Loose lay vinyl planks 14Nov 02, 2016 12:15 pm I've just done a rough calculation and I estimate we spent about $80/sqm on the Karndean (including floor prep, although our slab was so smooth I don't think much prep was needed.) The Karndean we chose was from the Opus range (915 x 152 mm) so not sure if that alters the price - the planks are still loose lay planks stuck down with a specific kind of adhesive. Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 16Nov 02, 2016 1:36 pm Thanks for the replies. I am checking out flooring extra maybe tomorrow and see what kinda price they can offer. If i can get it down to around 80 incld laying i would be satisfied. Its comparable to $40 tiles with $30-40 tiling cost. Re: Loose lay vinyl planks 18Nov 03, 2016 6:58 pm ZoePerth Nope - flooring guy just rocked up and installed them. Our Landsdale Build by Dale Alcock (Based on the Santa Monica) https://forum.homeone.com.au/viewtopic.php?f=31&t=83031 Re: Loose lay vinyl planks 20Nov 04, 2016 8:09 am I didnt get a chance to go yesterday. Got busy. I have come across post and youtube saying you should leave it for a couple of days in one of the room to acclimatise. I might check the karndean website to see if its true for their products to. It might just be old pratice from timber flooring days Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8370 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7637 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15252 |
