Browse Forums General Discussion Re: Living in a shed on acreage 13Oct 30, 2016 11:01 pm I'm thinking wood mezzanine , timber))) as its internal. I have the height. just wondering on designs and thinking about gyprock underneath the beams to look like ceiling as well as adding down lights. The area underneath is a main hallway /walkway. Re: Living in a shed on acreage 14Oct 30, 2016 11:02 pm I wish I could figure out how to post on here otherwise I'd send a photo ???? Re: Living in a shed on acreage 15Nov 02, 2016 10:37 am @FITG... This is for uploading a photo to photobucket. Other file hosting sites are similar. (Note: You wont see the image until you post your message/topic back here ) 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line which will copy it ( the line will turn yellow and say " copied " ). 5) Paste that into your post here then hit the submit button. If you have a smart phone then using Tapatalk etc for a direct upload here is probably easier... Other photo hosting sites like Imgur etc are very similar. 1 4561 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4891 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5393 |
