The chemical barrier you have to keep getting topped up. The physical barrier is more permanent and doesn't have the upkeep.
They emailed the documents yesterday but they wrote it the wrong way around - waiting for a new batch of docs again.
Browse Forums Building A New House Re: Building the Waldorf Grange by Porter Davis 84Oct 10, 2016 9:24 am Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 86Oct 11, 2016 9:06 pm Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 88Oct 11, 2016 9:55 pm Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 90Oct 12, 2016 6:26 pm Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 91Oct 12, 2016 10:10 pm So I Went past tonight and saw our first building casualty... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It looks like in the wind a window has fallen and broken the other... I'm also not sure how they will fix this... I mean with the double glazing do they change the whole panel or what... Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 92Oct 13, 2016 5:53 pm Oh no. How annoying. It's always windy on my block of land so I wonder if we will have any similar damage during the build. Re: Building the Waldorf Grange by Porter Davis 93Oct 13, 2016 5:56 pm yoyo72 how do you mean overhang on points, can you post some pics? we are also having some serious slab issues in fact i have free hanging frame as the slab wasnt measured properly and isnt wide enough sigh.... So if two of you have had a slab too small does that mean the slab size in their database is incorrect? Re: Building the Waldorf Grange by Porter Davis 94Oct 13, 2016 6:53 pm Waldorf_Grange_Build So if two of you have had a slab too small does that mean the slab size in their database is incorrect? That's a really good question... I spoke with my SS today (he seems really good at this stage ) he said that this is a normal occurrence and he has explained to me that the way the engineer has said to fix it is to drill into the existing slab and place large concrete pins and more reinforcing bar then they re concrete it so it basically becomes part of the original slab... On Another note, i called Stegbar today and asked as to what had been delivered to my property, according to them the windows delivered do NOT have the low-e Glazing, they are 4mm Safety glass, 12mm air gap, 4mm safety glass. So when i spoke to my SS i told him and he said they would work it out.. He isn't sure if they will send new windows or just re place them on site.. <--- this is something i would look into Waldorf_grange_build when you get to site as if i didn't say anything they would have just installed the ones without the Low-e. I will be interested which ones they give us when they do the order of the new ones as Stegbar have MANY types... Stegbar Low-e Brochure Stegbar Window efficiency ratings 2 More issue that require rectification:
Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 95Oct 15, 2016 2:11 pm bd3watson Waldorf_Grange_Build So if two of you have had a slab too small does that mean the slab size in their database is incorrect? That's a really good question... I spoke with my SS today (he seems really good at this stage ) he said that this is a normal occurrence and he has explained to me that the way the engineer has said to fix it is to drill into the existing slab and place large concrete pins and more reinforcing bar then they re concrete it so it basically becomes part of the original slab... On Another note, i called Stegbar today and asked as to what had been delivered to my property, according to them the windows delivered do NOT have the low-e Glazing, they are 4mm Safety glass, 12mm air gap, 4mm safety glass. So when i spoke to my SS i told him and he said they would work it out.. He isn't sure if they will send new windows or just re place them on site.. <--- this is something i would look into Waldorf_grange_build when you get to site as if i didn't say anything they would have just installed the ones without the Low-e. I will be interested which ones they give us when they do the order of the new ones as Stegbar have MANY types... Stegbar Low-e Brochure Stegbar Window efficiency ratings 2 More issue that require rectification:
It is a bit disconcerting that already so early in the build you have had multiple problems. Does this mean we have to be double checking and triple checking everything ourselves throughout the build? Lucky you checked about the glass but such a shame to hear no one else would have noticed unless you intervened. Re: Building the Waldorf Grange by Porter Davis 96Oct 15, 2016 3:10 pm so what is this e glass? was it in a promo? how do i know if i have it or not? assuming we are on the same promos as our houses are at similar stages, we are building a normal waldorf though not the grange but the promos for the prestige were the same... Re: Building the Waldorf Grange by Porter Davis 97Oct 15, 2016 3:15 pm Waldorf_Grange_Build bd3watson Waldorf_Grange_Build So if two of you have had a slab too small does that mean the slab size in their database is incorrect? That's a really good question... I spoke with my SS today (he seems really good at this stage ) he said that this is a normal occurrence and he has explained to me that the way the engineer has said to fix it is to drill into the existing slab and place large concrete pins and more reinforcing bar then they re concrete it so it basically becomes part of the original slab... On Another note, i called Stegbar today and asked as to what had been delivered to my property, according to them the windows delivered do NOT have the low-e Glazing, they are 4mm Safety glass, 12mm air gap, 4mm safety glass. So when i spoke to my SS i told him and he said they would work it out.. He isn't sure if they will send new windows or just re place them on site.. <--- this is something i would look into Waldorf_grange_build when you get to site as if i didn't say anything they would have just installed the ones without the Low-e. I will be interested which ones they give us when they do the order of the new ones as Stegbar have MANY types... Stegbar Low-e Brochure Stegbar Window efficiency ratings 2 More issue that require rectification:
It is a bit disconcerting that already so early in the build you have had multiple problems. Does this mean we have to be double checking and triple checking everything ourselves throughout the build? Lucky you checked about the glass but such a shame to hear no one else would have noticed unless you intervened. I'm hoping I don't have to look this closely at everything but if the problems so far are anything to go by then I guess I will have to... I'm just worried because I'm going interstate for 3 weeks during November so I guess I will have to trust they will do the job they are being paid for!! Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 98Oct 15, 2016 3:22 pm yoyo72 so what is this e glass? was it in a promo? how do i know if i have it or not? assuming we are on the same promos as our houses are at similar stages, we are building a normal waldorf though not the grange but the promos for the prestige were the same... Hey Yoyo, This is the sticker that should be on the windows... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The top line says the glass type and when I read it I was just a little suspicious because it reads like normal clear toughened glass... then I called Stegbar and asked to speak to someone Who deals with PD and I asked them what was deliverers and they told me none were low-e. Low e description can be found here http://www.build.com.au/low-e-glass It's basically a coating that stops the transmission of Specific wavelengths of light. It's part of the sieze the dream promotion, so I would assume you should have it... depending on when you signed on... Home Blog: https://waldorfgrange.wordpress.com/ Re: Building the Waldorf Grange by Porter Davis 99Oct 15, 2016 3:31 pm yes i just checked and we are on the live the dream promo and book says low-e glass included, didn't see any stickers on my glass at all but will check next time I'm at the block....thanks for pointing it out i would have missed that one completely (none of our windows are double glazed but should still be the low e glass as such) Building the Waldorf Grange by Porter Davis 100Oct 21, 2016 4:39 pm Had our frame inspection today... Darbecca stopped at 40 errors because "it is clear that no quality control has been performed on the frame" and that "this frame has an above average amount of compliance issues." Not to mention in big bold red writing it says reinspection required because it doesn't meet the engineers specifications.... This is beyond a joke!! I will update the blog later I'm just really annoyed at the moment... Edit: also they have said the frame is complete and have the audacity to send me an invoice... Home Blog: https://waldorfgrange.wordpress.com/ Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 13614 We spent close to 2 years in a process with TA. It was horrible..... we got to tender, and the first cut was 50% over our budget which "they care such about meeting ". We… 18 27840 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11454 |
