Browse Forums General Discussion Re: radical idea for deck rejuvenation Thoughts please. 8Sep 27, 2016 5:48 pm I hear you Stewie,no the walls are over all of it, and I don't want to go sabre sawing the whole lot out. I think I may have thought of a solution though.I have a 1200 W sliding fly door which leads out to 8 steps going down.All the risers are at 190 and the top one is onto the deck.If i was to go over the top with new decking the top riser would be 210.,but if I was to cut out the existing decking just in front of the door and recess a coir mat in and trim with some brass angle i think it would look ok.and still have my 190. Peed off.The old jarrah had been down about 15 years,and the newer merbau about 3 and both had aged to around the same colour.Wasn't till I sanded it i realised it had been Jarrah,and of course came up like a patchwork quilt after I oiled it. I think if I was to go over the top with new decking I would run it the other way,and if I sealed the bottom of the new boards first (for cupping) do you think I could get away with 1 screw in the middle,and at about 900C given that I am screwing it to the old deck which is really sound and flat? Re: radical idea for deck rejuvenation Thoughts please. 10Sep 27, 2016 8:38 pm Quote: I think if I was to go over the top with new decking I would run it the other way,and if I sealed the bottom of the new boards first (for cupping) do you think I could get away with 1 screw in the middle,and at about 900C given that I am screwing it to the old deck which is really sound and flat? Probably. But why use screws ? I'd prefer to whip out my nailgun and fire in some 50mm brads at every 450mm. Less noticeable than screw heads. As long as the existing decking is secured down hard , nails should be fine. Stewie Re: radical idea for deck rejuvenation Thoughts please. 11Sep 27, 2016 10:31 pm Mm,be ok wouldn't it,not as if the old deck is going to shrink and cause popping. Could always run a bead of silicon as well. Don't know about you but I am using silicon as an adhesive more and more these days in certain situations. Re: radical idea for deck rejuvenation Thoughts please. 12Sep 28, 2016 12:29 pm Horses for courses. I prefer to use a good grade construction adhesive like Sikkaflex where glue is needed and only use Silicon where a sealant is necessary. I must admit though, silicon does stick like the proverbial to a blanket. Stewie You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4844 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 26777 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9617 |
