Browse Forums Renovation + Home Improvement 1 Sep 18, 2016 12:58 pm Hi all I've just started getting my kitchen area ready for our new kitchen and found the existing plaster is no good. I would imagine it's from years of moisture sitting behind. Short of ripping the cladding off and Sarking that side is there any solutions any one can suggest? I have aquacheck to replaster and sarking i was going to use on the roof. Would a possible solution be sarking the gyprock side and aqua check after sealing up as many gaps etc in the external wall? Many thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Please help: wall water barrier 2Sep 19, 2016 5:02 pm felix_deLarge Hi all I've just started getting my kitchen area ready for our new kitchen and found the existing plaster is no good. I would imagine it's from years of moisture sitting behind. Short of ripping the cladding off and Sarking that side is there any solutions any one can suggest? I have aquacheck to replaster and sarking i was going to use on the roof. Would a possible solution be sarking the gyprock side and aqua check after sealing up as many gaps etc in the external wall? Many thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You need to find where the moisture is coming in from outside. No point installing new plasterboard etc inside if the timber frame is continuously wet otherwise it will eventually rot if it hasn't started to already. It is coming in from the outside isn't it and not the result of faulty pipework in the wall ? Personally I'd strip the internal lining off on the wall in question and have a good look before doing anything else. Stewie Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 2663 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 7718 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 11881 |
