Browse Forums Bathrooms and Laundry Re: New bathroom, toilet leak 9Aug 04, 2016 9:04 am Is there a floor waste in the bathroom apart from the one in the shower ? If there is ( and there should be ) , then there needs to be fall to it. BCA rules for wet areas. Stewie Re: New bathroom, toilet leak 10Aug 09, 2016 2:33 pm We had the building inspection done and the building inspector measured the fall of all the bathroom floors and they're fine. He said the same as the builder-that there is water coming from somewhere it shouldn't and it is still seeping out. Both the builder and the inspector are stumped. So we are returning the toilet that was leaking and hoping that will fix the problem. Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5122 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20344 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17467 |
