Browse Forums Bathrooms and Laundry Re: New bathroom, toilet leak 7Jul 26, 2016 9:22 am Yeah I agree, I was just trying to quote the requirements set by the AS rather than my own opinion on it just so the Op knows the min, set out by that book. Going above the min requirement in these wet area applications is something I encourage. Better more than not enough. Re: New bathroom, toilet leak 8Aug 03, 2016 10:59 am I was told that was the minimum fall for the shower but there isn't a standard for the main bathroom fall??? We have a building inspector coming out tomorrow so will hopefully have an answer then. Re: New bathroom, toilet leak 9Aug 04, 2016 9:04 am Is there a floor waste in the bathroom apart from the one in the shower ? If there is ( and there should be ) , then there needs to be fall to it. BCA rules for wet areas. Stewie Re: New bathroom, toilet leak 10Aug 09, 2016 2:33 pm We had the building inspection done and the building inspector measured the fall of all the bathroom floors and they're fine. He said the same as the builder-that there is water coming from somewhere it shouldn't and it is still seeping out. Both the builder and the inspector are stumped. So we are returning the toilet that was leaking and hoping that will fix the problem. Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5084 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17322 |
