Browse Forums Building Standards; Getting It Right! Re: [Urgent] Advise please - Weep hole 2Jul 20, 2016 6:28 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 3Jul 20, 2016 6:44 pm Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: [Urgent] Advise please - Weep hole 8Jul 20, 2016 7:22 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 19Jul 24, 2016 2:53 pm ZoePerth Surely if water is to drain out of the weep holes that can still happen when covered with grass or soil or pavers since they're all permeable? Seriously? Regulations (compliance) are formulated for different reasons and purposes. The matter of non compliance breaching the termite barrier is just one other reason for the weep hole mandated height compliance. ZoePerth Right but is it an issue to occasionally have a half inch of water sat in the cavity? I'm not being awkward I'm genuinely asking. It's how I've seen lots of builds in WA. Too many cowboys. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6329 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 12083 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3991 |
