Browse Forums Building A New House 1 Jan 28, 2009 9:19 am --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Moroka finish / Rendering costs? 6Jan 28, 2009 12:32 pm --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: Moroka finish / Rendering costs? 8Jan 28, 2009 3:23 pm ... built a Promenade with Clarendon. viewtopic.php?f=31&t=25104 20-10-09 - excavation and piering completed ... 12-04-10 - Basins fixed. Connecting to the electrical grid 23-04-10 - PCI 07-05-10 - HANDOVER! Re: Moroka finish / Rendering costs? 11Jan 28, 2009 8:47 pm Building Vancouver 33 - My Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=89689 Re: Moroka finish / Rendering costs? 12Jan 28, 2009 9:07 pm The render probably wont be more expensive post construction but messy it is so negotiate with your flowers!!!
Beware though render/bagging it all cracks and patching render is not a DIY job - its an art. It will crack not because its applied incorrectly but because all houses settle and masonry contracts and expands with the elements at a different rate to the render. Bagging is much easier to patch. Bagging is typically applied in a swirling fashion but some products nowadays are applied by a roller so have a smoother appearance. For mine it looks much better. So what does it all mean - render - expensive to apply and repair and bagging doesn't look as good but cheaper to apply and repair and the rolled application looks much better. Good luck! Moroka 13Jan 29, 2009 1:07 pm I thought Moroka could be done in a smooth surface like render? That's what we have chosen and we have been given a Moroka colour chart to choose from. On the Taubmans Moroka website it shows different textures??
themax Re: Moroka 14Jan 29, 2009 1:21 pm themax I thought Moroka could be done in a smooth surface like render? That's what we have chosen and we have been given a Moroka colour chart to choose from. On the Taubmans Moroka website it shows different textures?? themax themax, I've seen 2 different moroka finishes on EB display homes. One has the moroka applied in a swirl method - YUK! THe other was almost like render ie no obvious patterns. Our SS told us that the finish depends on the person applying the moroka. So he suggested that prior to it being applied to our house, a sample would be done fro me. Thay way I can insist on the plainer appearance and not that horrible swirl effect which looks like it's left over from the 70s. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade moroka 16Jan 29, 2009 4:12 pm Thanks Southies. I think that I will have to clarify with our colour lady next week and also will send an email to tender lady to confirm that we won't be doing a time warp back to 'livin'in the seventies'..couldn't stand it all over again...(skyhooks ...remember! )
themax Re: moroka 17Jan 29, 2009 5:21 pm themax Thanks Southies. I think that I will have to clarify with our colour lady next week and also will send an email to tender lady to confirm that we won't be doing a time warp back to 'livin'in the seventies'..couldn't stand it all over again...(skyhooks ...remember! ) themax Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Moroka finish / Rendering costs? 18Mar 13, 2011 1:47 pm I dont understand how people think that cement rendering is expensive..... I am a Solid Plasterer (cement renderer) and our price is usually at around $35-$45 p/square metre for smooth 10mm render!!! how is that expensive? now a bag finish like Maroka usually costs more for the material than it does for the labour. Alot of rendering jobs are done by cheap labour bought from overseas! bad bad bad. Keep the work in Australia for Australians Re: 19Mar 13, 2011 2:14 pm JB The render probably wont be more expensive post construction but messy it is so negotiate with your flowers!!! Beware though render/bagging it all cracks and patching render is not a DIY job - its an art. It will crack not because its applied incorrectly but because all houses settle and masonry contracts and expands with the elements at a different rate to the render. Bagging is much easier to patch. Bagging is typically applied in a swirling fashion but some products nowadays are applied by a roller so have a smoother appearance. For mine it looks much better. So what does it all mean - render - expensive to apply and repair and bagging doesn't look as good but cheaper to apply and repair and the rolled application looks much better. Good luck! Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4930 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7619 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5267 |
