Browse Forums Pools & Spas Re: Water Feature around pool area 2Jun 30, 2016 9:11 am Hi, was wondering if you had any full length shots of your pool and landscaping? thanks Re: Water Feature around pool area 4Jun 30, 2016 1:41 pm Hi Wall, I am about to be! we are just in the middle of getting pool quotes now but have included a feature wall and waterblade like you have as well.. we have to do a retaining wall across the back so your pics help to visualize how that may look yours is looking great by the way very neat! Re: Water Feature around pool area 6Jun 30, 2016 3:01 pm Wall Sounds great, What product are you planning to use on the feature wall? we have been quoted for stacker stone, however im thinking of doing Travertine on the coping and then over the feature wall to tie it all in... Re: Water Feature around pool area 9Mar 27, 2017 6:11 pm These guys make a good stainless steel feature head http://www.ebay.com.au/itm/WATER-FEATUR ... 3f662489b0 You can get them from Bunnings . Not all stores carry them in stock and sizing is limited . North Penrith store usually carry 600& 900mm units in stock Cheers Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3666 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4671 |
