Browse Forums Owner Builder Forum Re: Temporary Retaining Walls 2Jun 11, 2016 6:55 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Temporary Retaining Walls 4Jun 12, 2016 10:25 am Hi Chops Thanks for the info, just a couple of points Google maps lacks details, topo/contours, sometimes a closer photos down the boundary are equally helpful. The test/trail pits and bearing capacities are used to determine the pile/footing depths. What stage are you at have you sign the building contracts yet and whose decision was it to do the footing and pile retaining that way? I always suggest that clients get preliminary engineering options before hand reason being the quotes for such works will always be cheaper before than later when you have partialy committed and given a deposit..as there is no incentive for them to sharpen their pencil on the quote You can leave a PM if you wish Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Temporary Retaining Walls 5Jun 12, 2016 9:12 pm We are still discussing the project with builders so no contracts have been signed as yet. In either case, we only need a builder to oversee the project until lock-up at which point we will take over and complete the fit-out. If that doesn't work out then I'm more than happy to complete the entire project as an owner builder. The structural engineer decided to retain in this manner and overall I'm quite pleased with their work and ongoing support - definitely one of the better engineering firms we've worked with. We spent quite a bit of time discussing the entire project in detail (ICF basement walls vs core filled brick, suspended slabs vs posi floors, frame sizing, steels, shotcreting etc) before the detailed engineering work was completed. I just don't like the idea of literally sinking thousands of dollars into piers that are non value adding. Once the walls are completed they will serve no purpose, hence my question on temporary walls and other suitable alternatives. Our engineer has already advised that soldier piers as designed are the most cost effective solution, however I'd like to understand the alternatives along with some objective data so I can make a final decision and move forward. Re: Basement Temporary Retaining Walls 6Jun 13, 2016 9:23 am Thanks for the additional information? I assumed you had signed a building contract and you were left to deal with the builders design/retaining? In which case the Builder has a preference to a particular solution because their strengths/trades lie in that area..it may not be the most economical but boosts his overall profit. I find engineers think out side of the box for solutions but finding trades to think in similar relative cost savings is difficult.Hence the reason I work along the entire build chain. Originally I though we were dealing with footings? Constructing basements may or may not require temporary retaining walls. You have probably looked at these solutions but i will mentioned this for others For eg. Alternatively, on (or near) Boundaries we use sheet piling (see below my G+ for iso 3D detail/engineering/construction ) or deep concrete footings various waterproofing systems (costly) & drainage cavities can be used on the inside walls. $500 for a (obsolete) pile is a fair price .. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Temporary Retaining Walls 8Jun 14, 2016 9:33 am Chops_47 If $500 per pile is a fair price then I assume $1,000 per pile is a little too steep? All things being equal I would say Yes Chops_47 What is a realistic price for sheet piling, both temporary and permanent? Contact your state suppliers they should give you prices & contractors details. From my experience they are priced similar by many? I wouldn't recommend temporary piling the costs & difficulty of removal are the main considerations against. The savings is in offsetting part of the cost with another part of the basement element I had a quick look at the last project we did with piling the cost then was $900 p/m. BTW lysaght no longer has piling... its now imported from china. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3981 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1892 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6138 |
