Browse Forums Building Standards; Getting It Right! Re: Two garages built to the same boundary. Possible? 6May 19, 2016 4:16 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Two garages built to the same boundary. Possible? 7May 19, 2016 4:23 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Two garages built to the same boundary. Possible? 9May 19, 2016 10:36 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Two garages built to the same boundary. Possible? 12May 23, 2016 7:47 am 60 minute firewall can be attained with a brick wall. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Two garages built to the same boundary. Possible? 13Jun 27, 2016 12:47 pm Propose a boundary eaves detail for Council perusal. Details should address fire/ encroachment, stormwater and other relevant issues. You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 37026 0 10790 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4381 |
