Browse Forums Finishing Touch Help with brick, down pipe & fascia colour 3Apr 29, 2016 9:05 pm Build thread viewtopic.php?f=31&t=81011 Re: Help with brick, down pipe & fascia colour 4Apr 29, 2016 9:10 pm What colour are your window frames? If you have a surfmist garage door, surfmist fascia would work. Woodland Grey would also work just as well, it depends if you prefer a contrast or it all to match. With a woodland grey roof and surfmist garage, I'd do surfmist fascia and woodland grey downpipes. I definitely wouldn't do jasper if there's no other jasper on the facade. Re: Help with brick, down pipe & fascia colour 5Apr 29, 2016 9:33 pm Frye What colour are your window frames? If you have a surfmist garage door, surfmist fascia would work. Woodland Grey would also work just as well, it depends if you prefer a contrast or it all to match. With a woodland grey roof and surfmist garage, I'd do surfmist fascia and woodland grey downpipes. I definitely wouldn't do jasper if there's no other jasper on the facade. I am looking at doing Surfmist windows. It will look nice from the inside, and help frame the bricks a bit. Thanks for your input. Re: Help with brick, down pipe & fascia colour 6Apr 29, 2016 10:46 pm My external colours are very similar to yours - dark roof and dark brown bricks. The gutters match my roof; the fascia, downpipes, windows, and front door are in surfmist. I also have timber cladding and timber-look garage door to break things up along with a light grey render. Based on the colours you've mentioned you could either go with: 1) woodland grey fascia and surfmist downpipes 2) surfmist fascia and downpipes, or 3) surfmist fascia and woodland grey downpipes. Any of the above will work. Which one is the best would probably depend on your facade design and if you have any other features on it like cladding or render etc. But you're right - definitely don't introduce jasper. [sneakersss] yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7374 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4941 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3280 |
