Browse Forums Building A New House Re: Builder Failing To Do Job 5Apr 27, 2016 8:50 am Then your building authority would be the Department of Fair Trading: http://www.fairtrading.nsw.gov.au/ftw/T ... putes.page Unfortunately you cannot give a job to a builder and walk away with any confidence that things will work out well. This isn't an accusation, just a statement of fact. You can find your own building professional/consultant/inspector to have a look at the works on your behalf and do a report but be careful in your choice. Make sure whoever you appoint is experienced and competent. Ask for references. But your first port of call should be Fair Trading. Ring them and ask for some advice. Re: Builder Failing To Do Job 6Apr 27, 2016 9:14 am A I'd engage a structural engineer over building inspector. They are the ones with the qualifications that get taken notice of for any remedial work. First thing to do is tell builder to STOP. Mortar/brickwork sounds like they should pull down and start again. Our slab was poured wrong and framers and brickies kept going to plan. Caused issues. BUT anything can be fixed and to my builders credit, they did come good. I would have rather had my rooms a bit smaller than compromise the frame/structure which happened when they kept building. Der. We had frame overhang and brick overhang on load bearing walls. Two storey house. Not too good. All fixed now though and I love my house. Better to have a slow build that's done properly or stopped and made good than let them keep going and cover up. Good, polite communication is key. Best advice I can give is stay calm and non-emotional, it clouds your thinking and breaks down communication. Re: Builder Failing To Do Job 7Apr 27, 2016 9:39 am It sounds like you have done no prior preparation or investigation as to what you need to know or do...in fact you haven't even posted your thread in the correct sub forum. This might sound harsh but you needed to have prior preparation to be able to address issues like the ones you have already had and possibly others you don't know about. Your first step should be to get your own suitably qualified building consultant and discuss the situation so far with him/her. You should also learn to use this forum's search facility and also read through threads in General Discussion and also Building Standards; Getting It Right as a minimum to expand your knowledge base and learn from the experience of others. One of the most valuable tips you will ever get is to take photos of everything...inside and outside, even if you don't know you are taking photos of. Hundreds of photos! Good luck, I hope that the rest of your build goes smoothly. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Builder Failing To Do Job 8Apr 27, 2016 12:45 pm That's why this forum is so fantastic All sharing and caring and learning. Good tips SaveH20 ... yep photos! It's not Tamada's fault the slab was poorly done and doesn't know what to do. There is so much to read, it's overwhelming. We shouldn't have to know how to build our own houses or pay extras for experts to keep things right. Or know how to build to standards/specification, that's the builders job. That's what we pay them hundreds of thousands of dollars to do. I think it's good it's been posted here, keep people aware that they need to keep their eyes open Re: Builder Failing To Do Job 9Apr 28, 2016 8:51 am A lot of first time new home buyers are unaware that they can contract their own building consultant or what credentials to look for. I have often thought that an informative 'sticky' on this subject and related matters would be invaluable but then again, not everyone knows about Homeone either. Threads like this one are quickly smothered in the New Home sub forum, the more appropriate sub forum is Building Standards; Getting It Right. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Builder Failing To Do Job 10Apr 28, 2016 11:25 am This subforum is titled: 'Building a new house' that's what Tamada is doing (building a house). It's the right place ? Peeps are free to ask questions. It's up to us individually to answer. Welcome to the forum Tamada ? how are you going with it? Re: Builder Failing To Do Job 11Apr 28, 2016 11:52 am I think it's important to note that a lot of builders read these forums. So anything you say on Here make sure you've already discussed it with them. They don't like it and you want a good relationship with them, as they are building your house. There is an invoice for frame stage so get an independent inspector which will cost a few hundred dollars but will give you peace of mind. Even if you have a friend that's a bricky ask them. Looks not to standard to me but I'm not a bricky or a builder. So what I think is not to standard might be ok because they'll render it or whatever. Hope everything is sorted soon. I'm new to building too, my house is finished and I felt dumb the whole way through. Re: Builder Failing To Do Job 12Apr 28, 2016 10:39 pm I hope they do read the forums ... might make sure they do a better job! Come back and let us know how you go Tamada! Don't worry, at this stage they don't know who you are and you haven't said who your builder is, so all good Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10415 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11572 |
