Browse Forums Building A New House Re: Custom Build in Warrnambool 41Apr 14, 2016 5:25 am You're theatre is going to be amazing! Thanks for sharing your speaker plans... Definitely something we haven't given enough thought to and don't want to end up skipping over it during the build to have to try and do it after handover M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Custom Build in Warrnambool 42Apr 14, 2016 12:12 pm I had to make sure I have it right because we're planning on running the cables ourselves before the plaster goes on; the other thing is we're getting acoustic batts put in those walls so it would be exceptionally difficult to try and do any cabling in those walls down the track (which is why we're going to run some conduit to the projector location from the wall under the screen - that way if the cables/technology change down the track as they invariably will - we can just tape a string to the old one, pull it out, then use the string to pull the new one back through) I'm kind of stuck for what to do next though; I'm both waiting for my father to finish the Air Conditioning plan and spec so I can forward to the builder, and waiting to hear from the builder re the engineering for the retaining wall so we can get the site cut organised. In the meantime we're sitting waiting. Its odd because all along we didn't quite have the money we needed for the deposit and now we're finally where (we think) we need to be (pending confirmed final quotes) and suddenly I feel impatient. Interesting how that works! Re: Custom Build in Warrnambool 45Apr 19, 2016 7:52 pm The next stage of the estate must be getting close to opening up, they've got gutters, the road has been hotmixed, they've got drains, lamp posts; about the only thing not done yet is the footpath (the existing path ends about 2-3m shy of the end of our frontage) - with any luck they'll do the footpath soon and then remove their temporary fencing and people will stop using our land as a thoroughfare to check out the new section! It'll also mean we have a better idea of the frontage as the bottom corner has been a bit of a hole around the sewerage connections, footpath ending etc. Re: Custom Build in Warrnambool 46Apr 21, 2016 9:08 pm I know it's thinking a little far ahead, but what are your plans for your back garden? Is that a render of a patio type thing? And do you plan to lay turf of seed? ![]() Building Simonds Hudson viewtopic.php?f=31&t=80646 Re: Custom Build in Warrnambool 47Apr 21, 2016 11:20 pm At this point we're thinking of constructing a deck from the big stacker doors at the "rear" of the house about 3-4m deep and the full width of kitchen/dining area. Eventually that deck will get a roof but the deck will almost certainly come first sans roof. We also want a flat grass area between the house and north fence - all the way back to about 1m from the shed - this will require construction of a retaining wall (or two, later!!) and some fill to get it all level but I should have access to a bobcat to speed construction. We'll be putting down grass seed - I don't forsee us having the funds to afford to put down turf; especially as the big shed won't have any powerpoints or lights until we spend money on that, and we need to replace a fair bit of our furniture which is too far gone and which we've only been persisting with as we knew we'd replace it when the house was done anyway. Re: Custom Build in Warrnambool 48Apr 22, 2016 1:36 pm Well you'll definitely have quite a few projects to keep you going after you've finished building! It'll all be worth it in the end! Any idea when you'll start building yet? Building Simonds Hudson viewtopic.php?f=31&t=80646 Re: Custom Build in Warrnambool 49Apr 24, 2016 1:41 pm Hopefully sooner rather than later. We're just waiting waiting waiting now, really. Re: Custom Build in Warrnambool 50Apr 24, 2016 1:49 pm And waiting is the worst!! Haha have you already bought your land and it's titled and everything? Building Simonds Hudson viewtopic.php?f=31&t=80646 Re: Custom Build in Warrnambool 51Apr 26, 2016 11:56 pm Yep we've been titled for some time now; there are about 6 houses in our stage already occupied and the construction fencing has just come down from three more. Just keep driving past the block to make sure nobody is dumping stuff there. Probably about due to be mown again. Guess I'll need more fuel for the mower first lol. Have been back and forth with the builders about getting a price for 3 phase power; apparently I needed permission from powercor and I emailed them a few weeks back (to a couple of different email addresses) - one response was to send off a form requesting a connection and they'll quote it (but it costs $500ish even for a rough estimate) and then I sorta gave up and late last week I got a phone call in response to the other email I sent; to say that the pits (we have underground power) have 3 phase available to it's as simple as the electrician emailing powercor before connecting and then it's all good - so I've gone back to the builder and asked for a price - it might mean we can run a larger AC unit for similar cost to the single phase unit we've been looking at, as well as potential to connect 3 phase machines in the shed (which can often be purchased very cheaply ex machining workshops via grays online) It's much cheaper/easier to connect 3 phase at this point than later, as the whole house would need to be re-circuited to allow the load to be balanced on each phase (or so my understanding of the phone call from powercor goes) - adding it later would also mean we'd need to replace a single phase power meter with a 3 phase one, and replace single phase wiring to the shed sub board with 3 phase wiring. Re: Custom Build in Warrnambool 52Apr 27, 2016 8:17 am Ah very good! We drove past the other day to check out the area, it's really nice! Do they have plans on doing anything to the big reserve in the middle? I also know the lady who's building on block 21 I think, the Novara homes one that's nearly done by the looks. Do you reckon it will cost much more from the builders side of things to get phase 3 put in? Building Simonds Hudson viewtopic.php?f=31&t=80646 Re: Custom Build in Warrnambool 53Apr 28, 2016 12:54 am There's a bit planned for that reserve in the middle - a playground at the very least but looks also like a big climbing net, a basketball ring and some other bits and pieces. There'll also be a bunch of walking/scooting tracks etc down on the floodplain area (which is basically where the road ends at the bottom of the hill if you continue down past my block where the fence is at the moment). 3 Phase should hopefully only cost $1000-1500 to the house, I am assuming the cost will be a little higher by the time it's run to the shed too as that's a fair bit of extra cable; although at least the cost of excavation won't change for that. Re: Custom Build in Warrnambool 54Apr 30, 2016 7:47 pm Got our retaining wall pricing ($5300!) and shed plans back so we're getting ever closer to where we need to be! Good news is we can do our site cut whenever it suits now so we can at least start doing something productive-looking on-site! Re: Custom Build in Warrnambool 55Apr 30, 2016 7:52 pm Retaining walls are so expensive! ![]() Glad you can start getting things done on site though! It's always great to see a bit of progress! We built the Rathdowne with Simonds Express in Western Melbourne Site start Oct. 2015 Keys Jan. 25th, 2015 My build thread -here- Re: Custom Build in Warrnambool 56Apr 30, 2016 7:55 pm Wow, hopefully I don't need a retaining wall... My builder says it should be fine, maybe I need to leave some fat in case a retaining wall is needed. How high is the wall? Re: Custom Build in Warrnambool 57May 02, 2016 9:12 pm The wall varies, I think it's 1200mm at the highest point. Also got pricing back for 3 phase to both house and shed, $1,100 - seems cheap enough given the cost of even a single "phase converter" to allow the use of second hand 3 phase equipment in the shed down the track! Re: Custom Build in Warrnambool 58May 02, 2016 9:22 pm Hooray for being able to start at site. Being able to walk through the house that you have rendered so well will be great! Re: Custom Build in Warrnambool 59May 03, 2016 12:51 pm It is pretty exciting although I must admit still does not feel real - it probably won't feel that way until we actually break ground. Re: Custom Build in Warrnambool 60May 04, 2016 10:42 pm I'd get the gutters to match your roof and pipes to match the paint - otherwise they become a feature. Nice pick with the paint colours! 1 35341 6 57610 Sadly no movement on site since soak wells went in. There are also missing/wrong storm water drains which need to be sorted, along with a broken pipe. Plumbing has been… 14 38063 |
