Browse Forums Building A New House 1 Apr 25, 2016 12:54 am 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 3Apr 25, 2016 8:14 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Sewer down pipe - any suggestions? 4Apr 25, 2016 8:58 am 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 6Apr 25, 2016 11:27 am It is standard practice these days to run sewerage drop pipes inside. It would be shown on the plans you signed (but builders don't normally point out things like so most people wouldn't notice) I know on some top end houses they do insulate the pipes for noise reduction although the noise of the flush/cistern refilling is usually much noisier than water going down the pipe. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Sewer down pipe - any suggestions? 7Apr 25, 2016 12:22 pm what is the advantage of drop pipes inside? I thought it would have easy access if it's outside for any block in the future. disadvantage is noise and it is going to take a corner space. They will have to do a bulkhead to cover it I think. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 8Apr 25, 2016 9:22 pm You won't hear it. Ours comes down in our home theatre. Can't hear anything and there's no bulk head either. We've got an access hatch on the external wall. Re: Sewer down pipe - any suggestions? 9Apr 25, 2016 9:32 pm is the pipe exposed? it will not be withing the wall space, from the look of it. so need to have bulkhead to cover it. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 10Apr 26, 2016 12:13 pm From an aesthetics point of view it looks much better than having copious pipes across the walls on the outside of a house. Nearby to us are a couple of homes that had second storey additions done about ten years ago and they have run all downpipes /sewer pipes etc on the outside walls. It looks terrible. Stewie Re: Sewer down pipe - any suggestions? 11Apr 26, 2016 6:23 pm at the same time you don't want to run it through the room. it will take space and the room will loose it's dimensions. I don't see what it can't be run through the wall cavity? 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 12Apr 26, 2016 6:29 pm Can you post your plans? It should show where this is and how the wall will be. Unless they have put it in the wrong spot, which is unlikely, it will not effect the dimensions of the rooms you have on your plans. Re: Sewer down pipe - any suggestions? 13Apr 26, 2016 8:02 pm I don't have a pluming plan, only the external plan. they had dug and put the pipes before they did the concreting. They just did the internal pluming now and connected it. I didn't know it was going to be connected to the upstairs sewer. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 15Apr 26, 2016 9:31 pm I have not seen in any of the display house a sewer pipe running inside a house. I assume either they are within the wall cavity or outside. checked with another person who had three down pipe, two were within the walls. in my current house, it is outside, what's wrong in having outside. For me is would have been on a side of the house, would not have been visible much. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Sewer down pipe - any suggestions? 16Apr 26, 2016 9:44 pm Again, refer to your drawings. If you are building a house, you will have working drawings, elevations, etc. External plumbing is not the norm now, most estates and councils no longer allow it. I can say with almost 100% certainty that display homes have plumbing done exactly as yours is. Unless the pipe has been put in entirely the wrong place, which is impossible to know without seeing drawings, there is no issue. Re: Sewer down pipe - any suggestions? 17Apr 26, 2016 9:55 pm Quote: I don't see what it can't be run through the wall cavity? Most cavities in a brick veneer house are 40mm wide. Unless they chop out a large section of the timber frame as well which would weaken the stud wall considerably they would have to move your wall 60mm inwards. Stewie Re: Sewer down pipe - any suggestions? 18Apr 26, 2016 10:21 pm thanks for all your answers. If I had known that it was going to be inside the house, we could have brought it through the laundry room, which was adjacent to the room. too late now. 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3232 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6525 |
