Browse Forums General Discussion Re: Agi pipe drain - advice needed 2Apr 21, 2016 7:27 pm I would put a layer of agg in the trench 1st, then Geofabric in a U shape. Then 100mm socked agi then cover with agg and fold the fabric over. Then cover the lot with more agg. Re: Agi pipe drain - advice needed 3Apr 22, 2016 3:25 pm Matt1 I would put a layer of agg in the trench 1st, then Geofabric in a U shape. Then 100mm socked agi then cover with agg and fold the fabric over. Then cover the lot with more agg. Thanks. What size aggregate would be best do you think? Re: Agi pipe drain - advice needed 4Apr 22, 2016 8:13 pm I don't think it really matters. I've used both 10mm and 20mm agg. Re: Agi pipe drain - advice needed 5Apr 23, 2016 12:06 pm 10mm or smaller. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Agi pipe drain - advice needed 6Jun 14, 2016 1:57 pm bashworth 10mm or smaller. Hi Bashworth, Thanks for the reply. I note that on your website I have read that you don't recommend geofabric for drainage of retaining walls etc, would you still recommend this course of action for this application, where the water movement, once it gets going after a lot of rain, is a sustained flow rather than just seeping down behind a retaining wall? Also, a general question to everyone - how do you determine what size of agi-pipe to use? Is there any information around that mentions how much water the different sized pipes can absorb through the slots? Due to ease of installation I would prefer to stay at 65mm or below but obviously don't want any overflow from a backed-up pipe. Re: Agi pipe drain - advice needed 7Jun 14, 2016 4:18 pm Have you checked for silt pit requirements? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Agi pipe drain - advice needed 8Jun 14, 2016 6:28 pm bg100 bashworth 10mm or smaller. Hi Bashworth, Thanks for the reply. I note that on your website I have read that you don't recommend geofabric for drainage of retaining walls etc, would you still recommend this course of action for this application, where the water movement, once it gets going after a lot of rain, is a sustained flow rather than just seeping down behind a retaining wall? Over the years I have seen many aggi drains stop working because the geofabric has become clogged by silt, especially with high groundwater flows. If the aggi pipe gets blocked (and this will take a long time if you use a small aggregate pipe surround) the pipe can be cleaned out with a high water pressure drain clearing device. If a geotextile layer gets clogged the only cure is to dig the whole thing up. Unless you have to drain a very large area 65mm dia will be big enough although a better job will usually be 100mm as larger dia pipes can be laid to flatter gradients. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Agi pipe drain - advice needed 9Jun 15, 2016 12:00 am bashworth bg100 bashworth 10mm or smaller. Hi Bashworth, Thanks for the reply. I note that on your website I have read that you don't recommend geofabric for drainage of retaining walls etc, would you still recommend this course of action for this application, where the water movement, once it gets going after a lot of rain, is a sustained flow rather than just seeping down behind a retaining wall? Over the years I have seen many aggi drains stop working because the geofabric has become clogged by silt, especially with high groundwater flows. If the aggi pipe gets blocked (and this will take a long time if you use a small aggregate pipe surround) the pipe can be cleaned out with a high water pressure drain clearing device. If a geotextile layer gets clogged the only cure is to dig the whole thing up. Unless you have to drain a very large area 65mm dia will be big enough although a better job will usually be 100mm as larger dia pipes can be laid to flatter gradients. Thanks for the reply. Just wondering at what point you think a gradient becomes "flat" enough to warrant going with 100mm? The water flows out of the mini trench I have dug out fairly easily at the moment so there is a bit of a fall present. Re: Agi pipe drain - advice needed 10Jun 15, 2016 12:06 am SaveH2O Have you checked for silt pit requirements? I will be connecting this drain up to the stormwater system which will be improved with my backyard renovations so silt pits would be part of this. At the moment I just want to make sure the water gets out of the house! Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4549 Agreed. I just found out today the certifier has not given the final sign off. 2 4097 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8489 |
