Browse Forums Building A New House 1 Apr 17, 2016 10:38 am --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: North Kellyville / Kellyville - Setback requirements? 4Apr 19, 2016 10:30 pm --- I don't have a signature - just this sentence saying that I don't have one - that'll do! Re: North Kellyville / Kellyville - Setback requirements? 6Aug 15, 2016 2:32 pm Hi all, does anyone know if there are set requirements about the fence/gate in North Kellyville? I want to get a brick/metal fence but not sure what the process is, or if there is one with council? TIA Re: North Kellyville / Kellyville - Setback requirements? 7Aug 28, 2016 7:44 pm bluemetal77 Hi. Thanks for the replies, specially gandn. I managed to look up the DCP (after a gazillion clicks and different pages) and it says triple garages not permitted. That sucks, we had a 20m wide lot and would have loved to put one in. I also found information on side setbacks, which reads as follows: Side setback (min) Ground Floor: 0.9m (Side A), 0.9m (Side B) Upper Floor: 0.9m (Side A), 1.5m (Side B) Which basically means i can build 0.9 from both sides, but when i reach first floor, one side needs to go in by 1.5m. Which i can work with. However, i really don't know how to fill up 20m without a third garage.. lol .. An idea has popped in my mind which goes something like .. extended the double garage behind itself half way, that will provide the 3rd garage space .. so 2 cars back to front, and 1 car on the side. I'll work on this a bit more. Now i'm still searching for CDC requirements, which i believe are more strict? I may be wrong on this, but I think you can pass a wider garage if you call it a "workshop" on the side rather than just part of the garage. Might be worth discussing this with the builders you're considering as they can normally give insight into how to make it work. This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 4057 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20579 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 16318 |
