Browse Forums Eco Living Re: My rainwater system design 4Apr 09, 2016 7:03 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: My rainwater system design 6Apr 11, 2016 3:04 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: My rainwater system design 7Apr 12, 2016 8:53 am AS 2870 covers the requirements for reactive soils and houses. The second link in particular is a very good read. http://www.stormplastics.com.au/files/A ... enotes.pdf http://www.stormplastics.com.au/files/S ... arJuly.pdf I second that... very good read indeed. So this is what should be specified on drainage plans for reactive sites? How many builders, designers or surveyors would even know? Re: My rainwater system design 8Apr 12, 2016 12:49 pm You can also throw plumbers, architects and hydraulic engineers into that mix for all manner of things. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: My rainwater system design 9Apr 12, 2016 1:10 pm That's for the extra details. That helps make it clear. With the flexible poly pipe it should be easier to find a neat way to terminate it above ground. There is some quite serious variation in the cost on the tee with inspection opening. Bunnings have the Holman one for $40, and there's this place that has one for $11: http://www.pipeonline.com.au/listProduc ... S+JUNCTION It's probably not worth it after the shipping, but it might be worthwhile to get a few things at once. Re: My rainwater system design 10Apr 12, 2016 3:51 pm If they are in the trade Liliana - plumbers, electricians, concreters, builders etc and building on reactive soil, then as professionals they should know. Not to do so is just ignorant and amateurish. Stewie Re: My rainwater system design 11Apr 12, 2016 3:57 pm Onejohn, Pipeonline are wholesalers but the Bunnings one is very expensive. Postage is a trap with some online traders and you have to be careful of their charges. It wouldn't be worth buying a one off plumbing fitting. Most irrigation stores are much cheaper than Bunnings and other hardware stores. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: My rainwater system design 12Aug 21, 2016 5:10 pm Hi John Are you done, moved in and have full tanks? In the end did the builder install 75mm downpipes? With all this rain I've been cursing that we don't have a roof or downpipes to start filling tanks! We hope to at least have the slab poured by Christmas on our H2P site in Adelaide. Im interested to hear how you have got on. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19535 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31300 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8440 |
