![Building4my3tots](/i/63139_1436132932.jpg)
What size is the door? We should of did full height 2700, but it was too late.
Ours is 2700mm x 1585mm. 2400 is over and above standard so I am sure your door will look amazing and will be a talking point.
Browse Forums Owner Builder Forum Re: OB in Hume area - VIC. Fast forwarded + photo heavy 181Apr 03, 2016 7:23 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 182Apr 03, 2016 7:29 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 183Apr 03, 2016 7:30 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 187Apr 05, 2016 7:31 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 194Apr 05, 2016 10:19 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 197Apr 06, 2016 9:06 pm ![]() I'm sold!!! August smart finally a simple aesthetic solution. Have you got yours yet? If so does is feel well made? Kasra, received our smart lock today. Definitely chunky and feels good in hand. Probably expected it to be a little heavier but still great as it will be fixed on the door, won't be carrying it around. Should be installing front door tomorrow hopefully so will install that as well. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 198Apr 06, 2016 10:53 pm ![]() Does the August SL also have a key entry in case anything goes wrong with the batteries or electronics? (I'm wondering if that is what the little circle on the front is?) We have decided to mount it on the inside of the house so we can still use the key in case anything goes wrong. Door should open up as we walk to it from the outside but I would prefer to keep it on the inside to reduce the risk of it being pinched as well. Plus we would see it more often from inside the house ![]() = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 199Apr 06, 2016 10:58 pm ![]() I have no words to describe your choice! It is absolutely stunning! I can't wait to see the wall and pool area now. ![]() That door is stunning! You're killing me with your selections! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 200Apr 06, 2016 11:02 pm Good choice on the August. It is ment to go on the inside. They have also released a cam and keypad (these go outside). I don't think they look as good as the lock. Be prepared to spend a bit of time setting it up to get it to work exactly as you want. Using my LG-G4 to bring you this update. What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12821 ![]() I have posted this before: We hired Darbecca to do every stage inspection, and I strongly recommend them to anyone that asks me. They were amazing. Thorough reports… 2 5273 ![]() |
