Browse Forums Lighting + Lighting Design Re: Lighting plan 6Jan 20, 2009 12:30 pm Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Lighting plan 9Jan 20, 2009 2:03 pm ![]() I am definitely putting a fridge in the garage, and didn't even think of the GPO! Same as with a lamp on the wall opposite the front door! That's why it's really important to sit down with a glass of something, and think about where you might possibly put the furniture, then think about will you have enough overhead light to read a book, or something while sitting there. Think about tables and lamps, or even floor lamps. what about the Christmas tree with the lights? You'll need a GPO for that as well! ![]() Also, as Joles has mentioned, placement of switches is essential. We mentally walked through every room in the house and decided where we needed to turn the lights on and sometimes off, so we weren't walking in the dark, and also tried to group them together so there weren't switches everywhere! With regards to your kitchen, where the light is, you will be working in your shadow at the sink washing dishes after a huge party ![]() In your entrance on the right wall adjoining your bedroom, that's a bit of a 'dead' area, and may be a good idea to think about having a GPO here too, incase you want a feature table with another lamp or even artwork with the above picture lighting. Is one of the minor bedrooms going to be a dedicated study? Defiinitely need more GPO's there then! Two won't cut it ![]() Good luck! Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29668 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9567 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9330 ![]() |
