Browse Forums DIY, Home Maintenance & Repair Re: Deck Footing Anchors 4Mar 31, 2016 9:17 pm Its a timber deck. Doesn't matter if it's built by a rank amateur or a seasoned pro. It should be still be built right. I just think that they are a cheap option. Not better , just cheap. Stewie yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7324 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10245 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3321 |
