Browse Forums Bathrooms and Laundry Re: Terrazzo floor 2Mar 07, 2016 9:52 am I know a lot of the modern terrazo floors are epoxy based but the older traditional way was based on portland cement, sand and marble chips - used for centuries. A quick google turns up these guys http://www.allsafeflooring.com.au/index ... &Itemid=26 Stewie Re: Terrazzo floor 3Mar 07, 2016 2:49 pm Stewie D I know a lot of the modern terrazo floors are epoxy based but the older traditional way was based on portland cement, sand and marble chips - used for centuries. A quick google turns up these guys http://www.allsafeflooring.com.au/index ... &Itemid=26 Stewie Thanks Stewie. The allsafeflooring links to an anti-slip pack, not the actual terrazzo mix? I am looking for how to create a terrazzo mix to extend an existing floor with terrazzo. I found this link http://www.doityourself.com/stry/how-to ... zzo-floors The cement I could buy in a hardware shop but the stone and marble chips mix? Any ideas? Re: Terrazzo floor 4Mar 07, 2016 4:31 pm I'm unsure. Maybe contact one of the large terrazzo tile suppliers like these guys http://www.terrazzo.net.au/ The biggest problem apart from sourcing those chips will be getting a color consistent to what you already have. I've seen some terrazzo steps replaced on a few sets of stairs and the guys haven't quite got the colour right. They tended to stick out from the rest of the stairs. Stewie CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17087 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17924 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17672 |
