Browse Forums Building A New House Re: Who else is building with Eden Brae? 13447Mar 07, 2016 9:05 am Thanks Kim. Going to see if I can get ours on that wall but up under the bench so my appliances can reach it, and we'd also have the option for laptops etc too. Re: Who else is building with Eden Brae? 13448Mar 07, 2016 6:07 pm Hi all Did anyone get any emails from EBH asking yourself to apply for a Flood certificate through council ? I though this has nothing to do with us since EBH has to take care of this ? Re: Who else is building with Eden Brae? 13449Mar 07, 2016 9:38 pm Lincoln35_mckinley Thanks Kim. Going to see if I can get ours on that wall but up under the bench so my appliances can reach it, and we'd also have the option for laptops etc too. I would still go for one down the other end if you plan for appliances. It will be tricky to reach over that part of bench so you would have to walk around each time to plug in etc. I planned on using appliances in the corner by the cooker but have ended up using them a lot more in the little alcove by the fridge. Re: Who else is building with Eden Brae? 13450Mar 08, 2016 7:38 am kim_kdr Lincoln35_mckinley Thanks Kim. Going to see if I can get ours on that wall but up under the bench so my appliances can reach it, and we'd also have the option for laptops etc too. I would still go for one down the other end if you plan for appliances. It will be tricky to reach over that part of bench so you would have to walk around each time to plug in etc. I planned on using appliances in the corner by the cooker but have ended up using them a lot more in the little alcove by the fridge. It really is not the most functional kitchen when it comes to things like power points is it! I'd much rather have a power point easily accessible near the main bench because that will be the main prep area especially when I'm cooking with the kids. I'm planning on having my coffee machine and kettle in the niche so might not have room there for appliances. I had thought of using the corner power point too, because we will have the microwave in the pantry on one of those butcher block tables. I've also put a power point in there. What I would love is one of those power points that pop up out of the bench, that would be pretty cool Re: Who else is building with Eden Brae? 13451Mar 08, 2016 8:38 am Hi everyone, Has anyone else had a change of site supervisor during the build? We are almost finished bricks but just received an email last night saying there will be a change of supervisor. Has anyone got Shaun as their site supervisor? Cheers! Re: Who else is building with Eden Brae? 13452Mar 08, 2016 10:11 am Hi is anyone building or have finish building Livingstone 23 or similar house ? My theatre room is open (3 walled) I liked it due to fact it allowed light to hallway where as if closed off didn't allow nature light in has anyone closed it off or partly closed off if yes how much did it cost any picture would be helpful thanks. Re: Who else is building with Eden Brae? 13453Mar 08, 2016 6:17 pm swiftsport Hi is anyone building or have finish building Livingstone 23 or similar house ? My theatre room is open (3 walled) I liked it due to fact it allowed light to hallway where as if closed off didn't allow nature light in has anyone closed it off or partly closed off if yes how much did it cost any picture would be helpful thanks. I partially closed it off with two 820mm sliding door and plasterboard wall. I think that would be enough to allow sunlight. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Livingstone23 with Eden Brae Homes Re: Who else is building with Eden Brae? 13454Mar 08, 2016 6:33 pm Jahangir swiftsport Hi is anyone building or have finish building Livingstone 23 or similar house ? My theatre room is open (3 walled) I liked it due to fact it allowed light to hallway where as if closed off didn't allow nature light in has anyone closed it off or partly closed off if yes how much did it cost any picture would be helpful thanks. I partially closed it off with two 820mm sliding door and plasterboard wall. I think that would be enough to allow sunlight. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ THANKS for the help Jahangir, that is something I'm after how much they quote you please ? And did you get all the cupboards done from kitchen culture too? Re: Who else is building with Eden Brae? 13455Mar 08, 2016 7:12 pm swiftsport Jahangir swiftsport Hi is anyone building or have finish building Livingstone 23 or similar house ? My theatre room is open (3 walled) I liked it due to fact it allowed light to hallway where as if closed off didn't allow nature light in has anyone closed it off or partly closed off if yes how much did it cost any picture would be helpful thanks. I partially closed it off with two 820mm sliding door and plasterboard wall. I think that would be enough to allow sunlight. THANKS for the help Jahangir, that is something I'm after how much they quote you please ? And did you get all the cupboards done from kitchen culture too? I will do overhead cupboards and pantry after handover. Plasterboard wall - $200 Sliding door price depends on Corinthian door type. 2No. 2340x820 Moda PMODG 5 with clear glazing - $672 2No. 2340x820 RIMP paint grade with translucent glazing - $1422 Moda door https://www.corinthian.com.au/Products/ ... Moda-PMOD5 RIMM door https://www.corinthian.com.au/Products/ ... Range/RIMM Re: Who else is building with Eden Brae? 13456Mar 08, 2016 7:39 pm Jahangir swiftsport Jahangir [quote="swiftsport"]Hi is anyone building or have finish building Livingstone 23 or similar house ? My theatre room is open (3 walled) I liked it due to fact it allowed light to hallway where as if closed off didn't allow nature light in has anyone closed it off or partly closed off if yes how much did it cost any picture would be helpful thanks. I partially closed it off with two 820mm sliding door and plasterboard wall. I think that would be enough to allow sunlight. THANKS for the help Jahangir, that is something I'm after how much they quote you please ? And did you get all the cupboards done from kitchen culture too? I will do overhead cupboards and pantry after handover. Plasterboard wall - $200 Sliding door price depends on Corinthian door type. 2No. 2340x820 Moda PMODG 5 with clear glazing - $672 2No. 2340x820 RIMP paint grade with translucent glazing - $1422 Moda door https://www.corinthian.com.au/Products/ ... Moda-PMOD5 RIMM door https://www.corinthian.com.au/Products/ ... Range/RIMM[/quote] Thanks are you sure cost $200 only to erect wall and doors about 1422? Re: Who else is building with Eden Brae? 13457Mar 09, 2016 6:35 pm Anyone on here get the Baumatic Dishwasher one there package? , we have one and you can't fit Dinner plates in it upright!!, unbelievable Re: Who else is building with Eden Brae? 13458Mar 09, 2016 8:02 pm Hey Phil. Just a thought - have you got the upper basket in the lower height position (model BDW65S)?If so it might help to raise the height of the upper basket. Deposit paid 3/9/14. Tender signed 3/10/14. Contract signed 22/10/14 Construction commenced September 2015 PCI 7/3/16 Re: Who else is building with Eden Brae? 13459Mar 10, 2016 7:22 am Marko56 Hey Phil. Just a thought - have you got the upper basket in the lower height position (model BDW65S)?If so it might help to raise the height of the upper basket. Thanks for that Marko,didn't even know you could do that, you would have thought they install it in that position originally, all good now ? Cheers Re: Who else is building with Eden Brae? 13460Mar 12, 2016 8:45 am Hi All I am building with Eden Brae Homes, They quote for me about $4000 before the land registered , in case of my land is in 12,5 BAL zone . They provide all the aluminium mesh to all windows and doors that required However, after the registration, my land is not in that 12,5 BAL . So they are giving me back $4000. My question is: should I get it to be done after handover with the same material or just let the builder to finish the job ? Will it be a little bit saving or not ? Thanks guys I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23434 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223639 |
