Browse Forums Windows & Doors Re: Double glazing as an upgrade 8Mar 05, 2016 5:18 pm Stewie the biggest factor that improved our star rating was pushing our walls out to be square...which cost bugger all! Once we did that our house 'free running' was 5.1 stars which is already above the average for nsw...mental! Re: Double glazing as an upgrade 9Mar 05, 2016 5:37 pm Deejay, I went for double thermally broken aluminium with hidden hinges and 6.4-16-6.4 tilt and turn and I am so happy I did. They are amazing, best of all it was only 10K cost after taking the credit for the standard windows. The painters were there on a 42 degrees day and with no electricity or fans they said the house was very pleasant inside. I am very happy I went DG and would use the same company in a heartbeat. Re: Double glazing as an upgrade 10Mar 05, 2016 6:05 pm Wow Aussie! Can you pm me the company and their location pls! That's a huge gap...is it argon or air filled? Did you use low e on either pane? Also with the tilt and turn what screens if any fit them? Thinking of having them in our meals area where it's a long skinny window Re: Double glazing as an upgrade 11Mar 05, 2016 6:08 pm I'm so glad someone else sees the benefit of DG! My husband stills scratches his head and our friends think I'm nuts paying extra for it...cept my mate who works at Viridian! I know that they all see the sense once the house is built Re: Double glazing as an upgrade 12Mar 06, 2016 6:49 am Quote: Stewie the biggest factor that improved our star rating was pushing our walls out to be square...which cost bugger all! Huh? What do you mean by pushing the walls out to be square ? Stewie Double glazing as an upgrade 13Mar 06, 2016 7:50 am Probably easier to show you Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ that's the original builders plan
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is our modified version...no articulation at all just straight walls which increased our floor space too Re: Double glazing as an upgrade 15Jul 11, 2016 9:56 pm deejay08 Wow Aussie! Can you pm me the company and their location pls! That's a huge gap...is it argon or air filled? Did you use low e on either pane? Also with the tilt and turn what screens if any fit them? Thinking of having them in our meals area where it's a long skinny window Same here. Would appreciate the info on the company. Thanks Re: Double glazing as an upgrade 16Jul 12, 2016 8:39 pm deejay08 Should say not a huge leap on insulation...tender includes r2.2 to walls and 3.5 to ceilings so that shouldn't cost too much to up...but I'll call the window supplier myself on Monday to find out exactly what they've quoted...I've asked a few times but the cso for the builder never answers...they look at me like I have two heads when I say that thermal comfort is our biggest priority! If I was asking for a butlers pantry they'd not bat an eyelid! Our triple glazed windows with low-e glass and argon gas can achieve u value of just 0.8, which, while still inferior to your walls, would offer you the kind of thermal insulation all your friends and neighbours would be jealous of! At the moment, triple glazing is on a winter special and costs just $150 per window under 2.2 sq m to upgrade from double glazing while doubling the performance as measured by the u-value. This represents exceptional value for money and ultimate in comfort: thermal, security, and acoustic. Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au Re: Double glazing as an upgrade 17Jul 12, 2016 8:50 pm Omg! I paid $8600 for 4mm with 6mm argon gap and 4mm is plain toughened glass awning Windows with apparently qlon acoustic seals. U value 4.1 and shgco 0.50 I wanted the gap to be at least 12mm but this is what I have received. They are being installed with the frame this week wish I had received your reply a lot sooner This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19360 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 8764 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16270 |
