Browse Forums Pools & Spas Re: Any above ground pool experience 8Mar 02, 2016 7:04 pm Hi wheelieworks. What is the cost difference between the above ground version as pictured above & the fully in ground version? (As a rough guide) KDR Under the Flight Path - Dennis Family Homes (Hawkesdale) Re: Any above ground pool experience 9Mar 02, 2016 7:35 pm It is a how long is a piece of string question . Typically we install on difficult sites . On this site if we were putting it in the ground the it would be around $3000 less . They are best suited to steep & sloping blocks , where a hi end look is required but excavation is very difficult . On a supply side a 4m pool is a additional $4000 & a 7m around $7000. We fitted one last week in a land slip zone on a steep site . The piers & base came in around $13000. A I ground pool wasn't a option . The slab below has piers up to 4m deep . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Any above ground pool experience 14Jun 21, 2016 7:30 pm does the shell stand by itself od does it need additional structure + concrete? Re: Any above ground pool experience 15Jun 21, 2016 7:56 pm The shell support varies depending on depth out of ground . We always use concrete . Either a ring beam at ground level around base or a full slab underneath . It depends on height of pool , ground stability , & zone of influence factors . If pool is more than 800mm out of ground we use some galvanised side support braces to keep side walls straight The pool below is 1.3m above ground . It has 2 gal braces on each wall . In the picture it is framed up ready for blue board & tiles . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is where it is up to at the moment . Deck down & ready for tiles on water feature & glass fence Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Any above ground pool experience 16Jun 21, 2016 9:39 pm Thank you, that looks terrific what is the price range for installation if I may ask? Re: Any above ground pool experience 17Jun 21, 2016 9:47 pm Generally a installed pool with premium equipment is $26-$40,000 Then landscaping & fencing on top of that . Sizing from 3x1.7m -7x3.5m . Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11799 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13688 Hi All, I have been dealing with icare for insurance in completing our house after our original builder went bust. We have gotten to tender stage and one of the companies… 0 20816 |
