Browse Forums Heating, Cooling & Insulation 1 Feb 08, 2016 8:50 pm Has anyone gone for 2 layers of insulation rather than 1. I can get 2 x R3 to cover the ceiling for the same price as R5. In theory this would seem to work out to R6, but more work installing! Just wondering if anyone else has gone down this path? Re: Insulation - 2 layers better than 1? 3Feb 09, 2016 2:11 am The installation cost would probably have you, what is the price difference for the materials? Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Insulation - 2 layers better than 1? 5Feb 09, 2016 8:31 am Material cost is the same, for R5 or 2 lots of R3. Hubby is doing the installation, new house so should be fairly neat and clean, only 2 downlights to worry about, large area but doesn't seem overly difficult. Re: Insulation - 2 layers better than 1? 6Mar 01, 2016 2:02 pm Hello. When we inspect a ceiling before install we look at the condition of the ceiling cavity and the condition of the pre-existing insulation. It most cases you can lay batts over the top but you want to minimise the gaps as much as possible. We also look at the option of removal and reinstall. Where are you based? Feel free to call us on 03 9753 3811 if you have any questions that one of "Insulation Specialists" can answer for you. Samantha Re: Insulation - 2 layers better than 1? 7Mar 01, 2016 2:40 pm Thanks, we're in Adelaide, it's a new house. All sorted now, my husband is halfway through installing the batts. brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7691 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1961 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11406 |
