https://goo.gl/photos/XQs1e57nG95hve1i7
Let's see how this goes but you do have to have an android to use the link.
Von
Browse Forums Bathrooms and Laundry Re: Bathtub plumbing 21Feb 26, 2016 7:32 pm https://goo.gl/photos/XQs1e57nG95hve1i7 Let's see how this goes but you do have to have an android to use the link. Von Re: Bathtub plumbing 22Feb 26, 2016 7:42 pm This google link is for people with android. https://goo.gl/photos/XQs1e57nG95hve1i7 Can only hope it works. Von Re: Bathtub plumbing 25Feb 27, 2016 6:47 pm Remove the floor grate in the shower to see if there is a water seal trap there or if it is directed connected to the floor waste in middle of room If has its own trap in the floor in shower base you should b able to use a pipe reducer from at a guess 65mm should b the size pipe for shower an use a humdinger to instal the bath. It wont matter that the waste is not right above the outlet in perfect world when doing under floors sewers never put the waste right under the outlet. With a guess would allow 150mm but go to reece or plumbing shop and measure the height of 1 Pm if you need more info Re: Bathtub plumbing 26Feb 27, 2016 7:25 pm You're talking to a rank amateur here Traveln, what the hell am I looking for when I take off the floor waste cover in the shower? A trap of some sort, or just a pool of water in a pipe that indicates there's a trap there? Von Re: Bathtub plumbing 27Feb 27, 2016 7:25 pm You're talking to a rank amateur here Traveln, what the hell am I looking for when I take off the floor waste cover in the shower? A trap of some sort, or just a pool of water in a pipe that indicates there's a trap there? Von Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10629 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6289 I can totally relate to your shed project struggles—I recently tackled a similar ordeal, and it was quite the journey. Navigating through all those regulations and hoops… 4 7914 |
