Browse Forums Paving & Concreting Re: How do i know if the concreting is done right? 8Feb 26, 2016 1:03 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 9Feb 26, 2016 6:13 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How do i know if the concreting is done right? 12Feb 26, 2016 11:08 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 13Feb 26, 2016 11:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 14Feb 27, 2016 7:46 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How do i know if the concreting is done right? 16Feb 27, 2016 1:14 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How do i know if the concreting is done right? 17Feb 27, 2016 1:24 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 18Feb 27, 2016 1:29 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 19Feb 27, 2016 1:40 pm The principal document is (Australian Standards) AS2870-2011 Residential Slab and Footings and AS3600 Concrete design Section 3 which imo is the bare minimum and are simplified/summarized in the BCA (NCC) Section 4 Design by Engineering principles 4.1 ".... This section is used to extend the range of validity of, or to modify, the deemed to comply designs contained in Section 3 of this standard" Quote Depending on your ground conditions you slab may vary from on ground basic footing to suspended slab between piers.Blah,blah That is the engineers call ask them to explain it to you so you are able to make informed decisions .HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How do i know if the concreting is done right? 20Feb 27, 2016 2:53 pm Australian Standards (AS) are level 4a Deemed To Satisfy (DTS) solutions. They are not alternative solutions. Alternative solutions are level 4b. The use of the word "alternate" was confusing. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8328 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4485 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9214 |
