Hi,
I am a new guy. I want to change my car port to kitchen and living area. Someone can give me some idea about the concrete floor. I am not sure I need redo the concrete floor or has any other way.
Thanks.
Browse Forums Paving & Concreting Re: query about extension concrete floor 2Feb 24, 2016 8:51 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: query about extension concrete floor 4Feb 25, 2016 5:24 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: query about extension concrete floor 5Feb 25, 2016 9:34 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: query about extension concrete floor 6Feb 25, 2016 10:59 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: query about extension concrete floor 7Feb 26, 2016 9:11 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: query about extension concrete floor 8Feb 26, 2016 4:56 pm StructuralBIMGuy Tony1980 the design needs to satisfy the performance provisions in the NCC 2016->Structural stability P2.1 lists what is required to be checked/certified by an engineer. BTW,If it is not covered in the NCC then you are referred to AS2870 Residential Slab and Footings Section 4 -> Designed by ENGINEERING Principles Correct! But you obviously do not understand the meaning of exemption NCC3,2,5,2 is an exemption clause that kicks in under certain circumstances. It allows people to avoid wasting their money engaging engineers to reinvent the wheel. You preaching ,get engineer for everything, reminds me of a Chiropractor that once tried to convince me that they are a solution to all body ailments. Yeah Right! Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: query about extension concrete floor 9Feb 27, 2016 6:16 am building-expert It allows people to avoid wasting their money engaging engineers to reinvent the wheel. You preaching ,get engineer for everything, reminds me of a Chiropractor that once tried to convince me that they are a solution to all body ailments. Yeah Right! LOL,You need qualifications & licence to practice medicine as you do for engineering & society values these professions If you don't like the fact that Councils & others advise people to get engineers for their slab designs then that's your problem. As a structural engineer/repair contractor I would see far less problems on site if they did. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: query about extension concrete floor 10Mar 03, 2016 5:02 pm StructuralBIMGuy Tony1980 Thanks for your reply. The council just tole me to ask the engineerer. They don't have any idea. Your slab is Non-Compliant to make it compliant you will need to pull it up and redo it as per the NCC..or have it certified as equivalent or better by a Structural Engineer. ..they are not suppose to give advice on structural non-compliant elements, even tho your query may seem non structural? in a nut shell,generally, Surveyors can only deal with Compliance where as an Engineer deals with the LOT. Hi, Would you please recommend some construct engineering and energy assessor. Thanks. 2 7265 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6765 |
