Browse Forums Paving & Concreting Re: Advice to repair cracks in my Pad before applying livos 2Feb 19, 2016 10:10 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice to repair cracks in my Pad before applying livos 4Feb 19, 2016 9:04 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice to repair cracks in my Pad before applying livos 6Feb 20, 2016 8:25 am abbeybox Considering all I told the builder was that I wanted to oil the floor as a covering in lieu of tiles, lino, floor boards etc as it was the most cost effective option I am not going to hold him to ransom over a couple of cracks. That's fine leave it.. Given the choice most would spend an extra 100 bucks upgrading the steel abbeybox All I would like to know is if anyone knows a product I can use that will fill the cracks in the slab and allow the oil to soak in and not stand out like dogs whatsies. Not that I know of..try a small sample area abbeybox The house is at lockup BTW so I guess the cracking isn't going to get much worse. The slabs continue to shrink and crack over time but the the rate of cracking diminishes Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice to repair cracks in my Pad before applying livos 7Feb 26, 2016 8:14 am Hi Abbey, Did you ask Livos your questions? They have a sister company called Anro Floors that Grind & seal floors with Livos products, http://www.anrofloorcare.com.au/ they may be happy to tell you what products they use to fill cracks on their own jobs, I have found them extremely helpful with advice whenever I have had questions. Every slab has some cracks, so your problem is a common one. The cracks, even if filled will not look the same as the rest of the floor area. Where we have had cracks in build jobs with polished concrete, our contractors have used tenax (from granite benchtop companies) & /or epoxy with colour or concrete dust. These areas will need re grinding & sealing when patched – however I am not sure how the livos will go over these products. Rammed Earth Enterprises, Specialist Builders of Rammed Earth Walls. http://rammedearthenterprises.com.au/ I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2503 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 12056 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11247 |
