Browse Forums Building A New House Re: Byford Central-M3 Residential- Tiling, brick clean, floo 123Dec 03, 2015 9:42 am My Build: viewtopic.php?f=31&t=74866 Byford Central-M3 Residential- Tiling, brick clean, flooring 124Dec 08, 2015 7:44 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- HANDOVER Booked!! 127Dec 14, 2015 6:26 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- HANDOVER Booked!! 129Dec 16, 2015 4:23 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- HANDOVER Booked!! 131Dec 22, 2015 2:54 pm My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- Handover Done 132Jan 03, 2016 12:13 am Ultimate Homes PERTH '13 Dec Council App '14 Jun Slab '15 Jun Lockup Dec PCI '16 Jan Feb PCI 9 wks ago - still NOT in viewtopic.php?f=31&t=80759 Re: Byford Central-M3 Residential- Handover Done 134Jan 03, 2016 12:05 pm My Build: viewtopic.php?f=31&t=74866 Byford Central-M3 Residential- Handover Done 135Feb 17, 2016 11:27 am My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- Handover Done 136Feb 18, 2016 10:47 am Everything looks great, hope our loving your new home Fingers crossed the issues get sorted soon, must be frustrating... Look forward to some more pictures Byford Central-M3 Residential- Handover Done 137Feb 23, 2016 8:17 am The list of items still to be rectified from PCI Brick clean – On front, entrance, alfresco etc needs re-doing - Guys said the chemicals they were using were not working Drains at front not draining, floods front of property - Maint guys could not do as needs professional Grout from bath hob to vanity cracking at side of vanity - There is one small area that was not done Light switch – fan on the top instead of light - Maint guys could not do as hard wired and needs an electrician IKON glass and they will also be in touch in relation to missing strips at the bottom of the shower screen - DONE Paving under power box requires reinstatement Paving Driveway - Sinking RHS Top Paving Driveway – high lip in a few sections at road Paving - not level at garage door, doesn't seal Paving Alfresco – Chips, uneven etc Paving - Gap at front of house, gap at front door Paving - Falling apart completely at front Front archway - gap in gutter showing Gas system – Large dent in door – door pushed in Gas BBQ connection - Corroding - 6 month defect Tile grout not sealed – in all wet areas Power Points – Light switch still covered in corrosion Ensuite Light Switch dented Door - Handle internal corroding - 6 month defect M3 Residential Sign - To be removed - DONE Gas cooktop - burner not working - waiting for parts Oven - touch plate needs replacing - waiting for parts My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential- Handover Done 138Feb 24, 2016 9:18 am Gosh that is a very long outstanding list of issues, have they given you an idea of when everything will be fixed? Re: Byford Central-M3 Residential - PCI Defect Remediation 139Feb 24, 2016 9:33 am Its ongoing.. the paver came yesterday but didnt bring any new pavers with him..... so needs to come back to finish the defects. Waiting on parts, trades etc etc My Build: viewtopic.php?f=31&t=74866 Re: Byford Central-M3 Residential - PCI Defect Remediation 140Mar 10, 2016 4:00 pm Still waiting for the PRE CI defects to be finished.... seems never ending... My Build: viewtopic.php?f=31&t=74866 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11604 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5553 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10485 |
