Browse Forums Flooring & Floor Covering Re: Flooring without quading around skirting boards 3Apr 16, 2015 4:25 pm BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Flooring without quading around skirting boards 5Apr 16, 2015 9:38 pm BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Flooring without quading around skirting boards 7Apr 17, 2015 11:44 am Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 9Apr 17, 2015 1:18 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 11Apr 17, 2015 4:29 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 12Apr 17, 2015 4:32 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Flooring without quading around skirting boards 15Feb 13, 2016 7:27 am I'm thinking of using that border around the kitchen island to yvonneh! Is it expensive? Been looking at quick steps largo and Eligna range...it ain't cheap but looks amazing! There was no pricing for the borders in the catalogue... Re: Flooring without quading around skirting boards 16Feb 13, 2016 8:14 am That border looks great... Will have to ask our quick step supplier if they can supply it fit the island benches Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Flooring without quading around skirting boards 17Mar 30, 2016 2:03 am You should give the builder a sample of floor and underlay your putting down and get him to pass it on to the stone mansions so they can stop the waterfall end short the same thickness of the floor so you can just slide it under the waterfall end when it comes time for the install of the timber flooring and after installation you only need to cork small gaps here and there Building Standards; Getting It Right! Is this acceptable in a new house build. Floors where installed by builder. Already chips in board and skirting is not flush 0 165 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28312 |
