Browse Forums Bathrooms and Laundry Re: Bathtub plumbing 2Feb 10, 2016 11:20 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: Bathtub plumbing 6Feb 11, 2016 1:45 pm Even if you used one of those flexible pipes ( I googled what they were yesterday ) you would still be looking at something like 175mm from the underside of the bath to the floor only because of the space the fittings take up under the bath. Stewie Re: Bathtub plumbing 7Feb 11, 2016 1:57 pm Yep, I know that, not that I'm allowed to use a flexible connector. 175 mm would be acceptable anyway as the bath is only 330mm deep, so......if the plumbing pushed the clearance up to 250 mm, that wouldn't worry me as the husband has done a trial run and can get in and out of the would be tub. I hate slabs on ground because everything is literally set in concrete. It's always a nightmare to change the plumbing, Re: Bathtub plumbing 8Feb 25, 2016 2:55 am Is the bath having its own trap or is there a water trap in the concrete from the shower or is it a direct connection or does it go to a floor waste.mmm to many options with no pics or info. If not to late attach some pics Re: Bathtub plumbing 9Feb 25, 2016 7:42 am traveln Is the bath having its own trap or is there a water trap in the concrete from the shower or is it a direct connection or does it go to a floor waste.mmm to many options with no pics or info. If not to late attach some pics I did take photos but couldn't figure put how to attach them to my question. Will try again. Von Re: Bathtub plumbing 10Feb 25, 2016 8:40 am 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line and copy it. 5) Paste that into your post here then hit the submit button. If you have a smart phone then using Tapatalk etc for a direct upload here is probably easier... Stewie Re: Bathtub plumbing 11Feb 25, 2016 9:25 am Stewie D 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line and copy it. 5) Paste that into your post here then hit the submit button. If you have a smart phone then using Tapatalk etc for a direct upload here is probably easier... Stewie Thank you Stewie, will give it a shot. Re: Bathtub plumbing 18Feb 26, 2016 6:11 pm http://s465.photobucket.com/user/vonand ... l.jpg.html damned if I know Stewie, is the above the link? Re: Bathtub plumbing 19Feb 26, 2016 7:01 pm Sorry mate just checked out the pic and link you added and from my side its spam crap. Takes you to spamming adds etc or and a sign up $6 a mnth for something lol. Just recheck or maybe a simpke way for people who have android Add photos to google pictures then all have to do is add link on here if that helps In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6355 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9411 5 3926 |
