Browse Forums Bathrooms and Laundry Re: Slate tiles in the shower 2Jan 15, 2009 7:34 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Slate tiles in the shower 4Jan 15, 2009 7:53 pm Thanks for the quick replies.
What do you reckon I could use which would compliment the slate tiles? I'm just worried that it will look a bit like an after thought if it's a different tile and doesn't flow with the open plan. Re: Slate tiles in the shower 5Jan 15, 2009 8:00 pm If you did something like this you might be able to get away with it.
I would take the most common colour out of the slate tile to a tile shop and try and match a floor tile to it. Stay as close in colour as you can. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What colour wall tile are you using? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Slate tiles in the shower 7Jan 16, 2009 2:34 pm This looks good.... If you can possibly, a bit darker wall tile, or more of a stone colour. The dark brown for the floor tile is good. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3344 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 351 |
