Browse Forums Kitchen Corner Re: Laminate panels for island ends 2Jan 23, 2016 1:51 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate panels for island ends 4Jan 24, 2016 12:42 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate panels for island ends 6Jan 24, 2016 4:54 pm Leksie5000 [Ah I see.. Well ours is the polytec ravine colours? Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 So polytec ravine comes as a laminate and also 18mm prefinished board. Two completely different products! Again more info needed. The laminate is only 1mm thick and glue to a substrate on all faces and edges, the corners unless post formed chip quite easily. The pre finished board comes either 16 or 18mm thick finish in ravine on both sides. Once cut to size the edges are normally finished with 1-2mm pvc edging which is a lot stronger than laminate. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate panels for island ends 7Jan 24, 2016 6:02 pm CuttingEdgeKitchens Leksie5000 [Ah I see.. Well ours is the polytec ravine colours? Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 So polytec ravine comes as a laminate and also 18mm prefinished board. Two completely different products! Again more info needed. The laminate is only 1mm thick and glue to a substrate on all faces and edges, the corners unless post formed chip quite easily. The pre finished board comes either 16 or 18mm thick finish in ravine on both sides. Once cut to size the edges are normally finished with 1-2mm pvc edging which is a lot stronger than laminate. Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Laminate panels for island ends 8Jan 25, 2016 7:46 am Leksie5000 [Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish. Perfect, that wont chip and is much better than laminate for those areas! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate panels for island ends 9Jan 26, 2016 12:23 am CuttingEdgeKitchens Leksie5000 [Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish. Perfect, that wont chip and is much better than laminate for those areas! Learn something new every day.. It's a pretty decent outfit I think whose doing our cabinets so I wasn't too worried Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Laminate panels for island ends 10Jan 26, 2016 1:23 am CuttingEdgeKitchens Leksie5000 [Ah cool. Just checked our detail it's "polytec melamine board with PVC dura edge" on the island bar and and drawer fronts. Rest of the kitchen is 2PAC satin finish. Perfect, that wont chip and is much better than laminate for those areas! Learn something new every day.. It's a pretty decent outfit I think whose doing our cabinets so I wasn't too worried Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Laminate panels for island ends 11Jan 26, 2016 2:04 pm Thanks CuttingEdge. Our plans say standard melamine with 1mm PVC edge. The specs for end panels just say80mm mitered polytec melamine, and the doors for the island say polytec melamine with 1mm PVC edge. Reckon that's alright? Re: Laminate panels for island ends 12Jan 26, 2016 4:33 pm Ursula123 Thanks CuttingEdge. Our plans say standard melamine with 1mm PVC edge. The specs for end panels just say80mm mitered polytec melamine, and the doors for the island say polytec melamine with 1mm PVC edge. Reckon that's alright? If the 80mm end panels go to the floor and are mitred then the corners will be very week. A knock with anything hard will dent/chip the corners easily. Just try and be very careful. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate panels for island ends 13Jan 26, 2016 6:16 pm Hmmm it's not too late to change! I was thinking of doing something different (and cheaper) than the stone waterfall ends. I've seen thick end panels with a profile, would that be vinyl wrap do you think? Thank you for your advice, I really appreciate it. Laminate panels for island ends 14Mar 14, 2016 2:49 pm Ursula123 Hmmm it's not too late to change! I was thinking of doing something different (and cheaper) than the stone waterfall ends. I've seen thick end panels with a profile, would that be vinyl wrap do you think? Thank you for your advice, I really appreciate it. Hi Ursula I'm looking into something similar to what you were asking. Would be great if you went ahead with it. I have a 40mm overlap on each side of my bench top, looking at options of either timber or if it can be done laminate good, even vinyl wrap sounds good as long as it matches cabinetry. Here's a pic of what I want to achieve Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have same colour cabinetry. Look forward to hearing your progress viewtopic.php?t=79203 Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 1710 0 11223 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6627 |
