Browse Forums General Discussion Re: new garage... 8Aug 09, 2006 7:52 am OK, try and look at it this way.
Take out the cost of a building permit for at least $1000.00, plus an insurance policy for another $1000.00 and a set of plans and engineering for another $1000.00. That leaves you with $17000.00 Assume that the overall cost will be 60% materials, therefore you can afford $10,200 worth of material and $6800 worth of labour - this is the general labour material breakdown of domestic building work although it could easily go 50/50 as well. These prices include the 10% GST don't forget! Average Labour rate of say $35.00 + GST per hour gives you enough money pay for about 176 hours TOTAL. That is one man/personfor 4 weeks and 2 days ONLY - there is nothing left in the piggy bank once that is gone. I don't know if you have done much building jimmy but one person, working alone (if it were possible) would not get the entire job done in such a time frame. Options: make it smaller, flat tin roof, semi open walls (eg: 1/2 a carport) and whatever else you can fit into the budget. Hope that helps a bit, let me know if you have any queries. Re: new garage... 9Aug 09, 2006 4:40 pm thanks builda. i havent done much (if any ) building work. Tho i have work as a timber floor layer for a year.
so anyways, i have an old fibro double tandem garage(rear lane access),tin roof, that needs repair as the frames decaying and plasterboards falling.. can i repair the old garage ? ..is it possible to just replace materials,eg..frames,plasterboard walls,roof (saving time/cost on permit,planning and designing ect .?) i need to have a garage to work on my bike and i have plenty of tools ,or else i'd settle for a carport and tin shed..its quite concerning to learn how much a garage cost.quoted by realestate salesman " mate, double brick garage would cost you 15- 20 gran ,single prolly 10-15" from your advises,i was able to worked out a budget and plan for my bathroom..now im very confuse as what to do with the garage . whats my best option in this situation?..what would you do and how much to spend? Re: new garage... 10Aug 10, 2006 3:00 pm Quote: can i repair the old garage ? ..is it possible to just replace materials,eg..frames,plasterboard walls,roof (saving time/cost on permit,planning and designing ect .?) Quote: whats my best option in this situation?.. Quote: and how much to spend? Re: new garage... 11Aug 10, 2006 4:56 pm Quote: Depends how much you've got! You can spend $10,000 on a repair or spend $100,000.00 on a double garage with ensuite and loft. Pick your budget first and then design to that budget. Don't design the dream garage before you have some idea what the end costs will be as you will only waste your time and money in the meantime ur rite builda.i have had a dream garage in mind without knowing the cost...assumptions killed my dream .. wel, i think i'll repair the old garage. (i initially wanted to relocate garage also) . im assuming this will only cost me for material and labour. we dont have a budget for the garage yet. we're just looking for the best inexpensive method. My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2676 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17203 |
