Browse Forums Kitchen Corner Re: Kitchen design - suggestions or thoughts? 10Jan 07, 2016 6:52 am svard75 Personally this last image makes more sense. Think about having an island vs wrap around. People will have to walk all the way around to get behind the cabinets or jump over. I also think the sink should be between the windows and if possible have one large window vs two smaller ones. I personally spend more time at the sink than at the stove. Our sink is as shown - double - and it is quite good - you just get use to where it is. BUT - we do have quite a big bench. So lots of space. Re pantry - size is relative - but the WI pantry does give you room to set up things and store long life items. Also - allows ease of access to all items. Our kitchen is longer - if you slid the end bit in that picture (fridge and ovens etc - around - and made the bench longer you'd get the idea. Agree on being able to walk around it - we also have our internal access door at one end - next to fridge. Great for groceries etc. Re: Kitchen design - suggestions or thoughts? 11Jan 07, 2016 6:53 am I still have trouble finding things at times - Mrs SM claims I don't look - BUT I do ... Re: Kitchen design - suggestions or thoughts? 12Jan 07, 2016 1:07 pm svard75 Think about having an island vs wrap around. People will have to walk all the way around to get behind the cabinets or jump over. I also think the sink should be between the windows and if possible have one large window vs two smaller ones. I personally spend more time at the sink than at the stove. Hi and thanks for the feedback, unfortunately the windows have been ordered so its too late to change them. We have a sunken lounge room next to the kitchen that's why the building designer only put 1 step down to that space (you can see better in this plan) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If we have an island bench that would create 2 ways to get into the kitchen but would people feel its a pain (or dangerous) to have a step so close to the edge of cabinets like this plan? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen design - suggestions or thoughts? 13Jan 07, 2016 6:47 pm Interesting about the step up. Was that intentional? Most modern home designs are integrating the kitchen and living/dining room areas so the transition is seamless. Step down/up is very dated design. It's still not too late to implement a change control to have one large window instead of two small ones and the sink in place of the stovetop. It may cost you but it's worth it for that change. I searched houzz.com for sunken dining rooms and found very few where the kitchen and dining rooms were not on the same level. Perhaps repurposing the family room as a dining room would work better You really wouldn't want to have to step up and walk all the way around to the kitchen. The other risk is if someone is carrying a large roast from the kitchen to the dining room they may fall at that transition. Anyway this is just my opinion, however it is based on research by simply typing in modern kitchen design into google images. Re: Kitchen design - suggestions or thoughts? 14Jan 07, 2016 7:15 pm svard75 Interesting about the step up. Was that intentional? Most modern home designs are integrating the kitchen and living/dining room areas so the transition is seamless. Step down/up is very dated design. I agree but we are gutting and rennovating an existing house that had a 70s step down extension - it would cost too much to bring our back section up to be level with the rest of the house. We have removed the old 70s spiral staircase though! Thanks for the suggestion re swapping the sink - where would you suggest the cooktop & range go in that instance? Kitchen design - suggestions or thoughts? 15Jan 07, 2016 8:57 pm What about a stove and hood where the double ovens live and install sink where windows are then have overhead bins on either side of the windows and a horizontal cabinet above the sink for perhaps glasses. The dishwasher should be close to the sink from a workflow perspective so close to the living room. That would form a nice workflow triangle. Also perhaps consider having the kitchen only extend to the end following the step. This way you can kind of hide the step by having the stools in the living room area. Not sure if that makes sense. A C shaped kitchen. ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 16013 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 39164 Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 19261 |
