Browse Forums Building A New House Re: Metricon Glendale 50 Limited Edition 7Jan 01, 2016 10:40 pm Lovely selections, gee you have done well doing some colour selections already! We aren't booked in til end of January. I'm thinking greys/whites/timber theme for inside Re: Metricon Glendale 50 Limited Edition 8Jan 02, 2016 6:41 am Emmz70 Thanks Emmz70. May i ask for the lighting, what is the quote like? For example, from existing batten light change to led? I think metricon is using viewlight ? Weblink-http://www.viewlight.com.au/ secondly, if needed a new led point what are the charges like? Lastly, what other cost will incurr if additional light point or switch required? Like RCB breaker? Have you upgraded the heating to zoned or with cooling? Cheers, have a good day Sent from my SM-N910G Re: Metricon Glendale 50 Limited Edition 9Jan 02, 2016 6:46 am kylz4 Lovely selections, gee you have done well doing some colour selections already! We aren't booked in til end of January. I'm thinking greys/whites/timber theme for inside Thanks kylz4. we do cut out from those display brochures we visit and collect the theme that we like for a start. After we sign the deposit, we request to go studio M to have a feel. we will be going again in mid Jan. Fyi, you can go studio m as many times you want before the appointment. Just for preparation. Sent from my SM-N910G Re: Metricon Glendale 50 Limited Edition 10Jan 02, 2016 9:28 am Yes we have been to the Geelong studio m and Melbourne studio m once, booked to go again on 9th Jan ? Re: Metricon Glendale 50 Limited Edition 11Jan 02, 2016 12:37 pm FYI, Electrical Pack is as follows: for $2850 Provide Electrical Pack 1 including: * (13No) Additional wiring points for downlights as shown on electrical plan. * (21No) Viewlight LED dimmable downlights with 70mm (nom) non-directional face plate and 120 degree beam angle in lieu of standard ceiling light points. - Wattage: 10 watts * (10No) Double power points. * (3No) Dimmer switches. * (1No) Additional light circuit (if required). * (1No) Additional power circuit (if required). Note: Downlights cannot be used in a plaster niche. This item is subject to lighting regulations and may require an upgrade to ceiling insulation. This upgrade will be determined after an electrical consultation and the customer will be charged accordingly (if required). - Owner to nominate face plate colour: White or Satin Silver Metricon Glendale 50 Limited Edition 12Jan 02, 2016 10:21 pm vintay68 Emmz70 Thanks Emmz70. May i ask for the lighting, what is the quote like? For example, from existing batten light change to led? I think metricon is using viewlight ? Weblink-http://www.viewlight.com.au/ secondly, if needed a new led point what are the charges like? Lastly, what other cost will incurr if additional light point or switch required? Like RCB breaker? Have you upgraded the heating to zoned or with cooling? Cheers, have a good day Sent from my SM-N910G Hi Vintay Costs depend on what selections you make. In a matter of 15 mins we were @ the 10k mark hah. So easy to spend money on this day. The program they use is user friendly and the ladies are fantastic We upgraded our standard heating to 4 zone. (Being double storey). This suited our situation because we preferred to have our master suite downstairs. We could then zone our heating to certain zones. We selected 4 but you can request for more. Once you finish electrical you will attend Heating and cooling selections and they are very helpful. These are some quotes: Heating is top quote and the remaining cooling Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is their best cooling that's suitable for big homes: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Prices can range up to 25k For lighting if you want to replace batons they are as follows: Wiring (internal & external) $56 LED 10w - $45 External Wall light point 15w - $65 External ceiling light point weatherproof - $70 Under cabinet light with box - $125 External Junction box - $56 40amp circuit Breaker costed - $650 Two way switch - $51 Dimmer switches - $82 Single power point - $55 Double power point - $61 Double power point to Island bench - $95 Quadruple power point - $117 Single weatherproof power point - $90 Double weatherproof power point - $120 Floodlight - $90 Extra light circuit - $168 Extra power circuit - $168 Airflow exhaust fan - $155 Pre-wire ceiling fan - $95 Phone point - $130 Data point - $130 Tv point - $130 We opted to get ceiling fans, cooling and feature lights handover. I hope this is helpful, a lot of people choose to get down lights later because they are much cheaper elsewhere and more wattage. We just decided to go ahead with M for downstairs and living areas, one less hassle for us viewtopic.php?t=79203 Re: Metricon Glendale 50 Limited Edition 13Jan 03, 2016 12:54 am Hi Emmz70, Thanks so much for the costing. At least I wouldn't get a shock. With the 4 star heating with 4 zone and controller, which model of the controller are used in the quote? How many controllers are there? Likely I will do up evaporative cooling and refrigerated cooling after handover. Btw, have your built started? Thanks for everything. Sent from my SM-N910G Re: Metricon Glendale 50 Limited Edition 14Jan 03, 2016 5:59 am vintay68 Hi Emmz70, Thanks so much for the costing. At least I wouldn't get a shock. With the 4 star heating with 4 zone and controller, which model of the controller are used in the quote? How many controllers are there? Likely I will do up evaporative cooling and refrigerated cooling after handover. Btw, have your built started? Thanks for everything. Sent from my SM-N910G Hi Vintay 4 controllers for each zone. Braemar model. They have other options as well when it's your appointment time Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Still awhile for our build. Our land doesn't title until June. We managed to push our contract signing to the 18th this month and then we can finally do tiling appointment with Beaumont tiles. Then it's wait, wait, for June I will definitely be following your build and looking forward to all our exciting adventures for the new. viewtopic.php?t=79203 Re: Metricon Glendale 50 Limited Edition 15Jan 03, 2016 8:56 am My land titled at June too. What a coincidence. I've yet to set the appointment as I would like to gather as much information as I can on the cost and work on my budget first. How exciting, thinking of both home built at the same time. Thanks again. Have a lovely Sunday. 😉 Sent from my SM-N910G Re: Metricon Glendale 50 Limited Edition 16Jan 03, 2016 9:05 am I like your color selection. I'm very interested to see how your kitchen turns out. I've been considering something similar myself. Congrats on your purchase and enjoy the journey. Joelleg6 Our build thread - Acacia34 by Orbit Homes viewtopic.php?f=31&t=81316 http://bordoncasaacacia34.blogspot.com.au/ Re: Metricon Glendale 50 Limited Edition 17Jan 03, 2016 11:53 am vintay68 My land titled at June too. What a coincidence. I've yet to set the appointment as I would like to gather as much information as I can on the cost and work on my budget first. How exciting, thinking of both home built at the same time. Thanks again. Have a lovely Sunday. 😉 Sent from my SM-N910G Yes it's very exciting and no doubt time will go quick I was looking at your house plan. Are you getting an outdoor area built later on? Why you've decided to close the area off? viewtopic.php?t=79203 Re: Metricon Glendale 50 Limited Edition 18Jan 03, 2016 12:00 pm Yes, a veranda with clear polycarbonate roof from back of garage till family or rumpus room after handover. Yet to consider decking or exposed aggregate on that area. Sent from my SM-N910G Re: Metricon Glendale 50 Limited Edition 19Jan 03, 2016 12:21 pm vintay68 Yes, a veranda with clear polycarbonate roof from back of garage till family or rumpus room after handover. Yet to consider decking or exposed aggregate on that area. Sent from my SM-N910G Very nice. We decided to get decking through M thinking we are still deciding to get them to extend another metre or more or get extension later on. $200 m2 through M. They also have an external landscaper we enquired about so may look into that as well. Can't wait to see your updated plans better to get all structural done earlier because we made dramatic changes and we were charged 1k for variations. viewtopic.php?t=79203 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11168 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8588 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 18209 |
