http://www.hikvision.com/UploadFile/image/2013082213464567195.pdf
I have 7.
Browse Forums Safer Living Re: IP CCTV system recommendations 130Dec 12, 2015 9:49 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: IP CCTV system recommendations 133Dec 13, 2015 1:10 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: IP CCTV system recommendations 136Dec 14, 2015 9:18 pm Duty is/was payable on the total >= $1000USD. I'm not sure what it is now. Most of the sellers are willing to mark it as gifts and low ball the value to get you under the threshold. Be careful though that if it's marked too cheap then it also comes under the scrutiny of Customs. Bear in mind though that what you're purchasing from aliexpress would now be China region cameras that have been hacked to english so there will be no firmware updates available without messing around with various things first. They will only work on China region NVRs generally with newer firmware. So if you do what to go down that route, get your cams and NVRs together all from aliexpress and you'll be less likely to have compatibility issues. Re: IP CCTV system recommendations 139Dec 15, 2015 10:18 am Crazyk Of those who have imported your items from Aliexpress of the other, have you had to pay any duty? Nope, no duty or GST (on purchases less that $AU1000). However that GST limit is going to change courtesy of Gerry Harvey's lobbying. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: IP CCTV system recommendations 140Dec 15, 2015 11:10 am I purchased the NVR and cameras from seperate sellers in seperate transactions. So was under $1,000 limit. They arrived yesterday so won't be hooking them up until Xmas but glad they arrived hadn't bought anything that expensive from China before Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20651 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19517 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 |
