Browse Forums Home Theatre & Automation 1 Nov 21, 2015 7:18 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Network Confusion.. Need Help!! 3Nov 21, 2015 8:51 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Network Confusion.. Need Help!! 6Nov 29, 2015 4:14 pm Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Network Confusion.. Need Help!! 8Dec 10, 2015 9:00 am Yeah it's all in the same location so probably will be housed together. Yes we do have a oversized garage, i like to tinker lol. We also have our electrical sub box located on the same wall (too many circuits to fit in meter box haha) Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: Network Confusion.. Need Help!! 9Dec 30, 2015 1:47 am Definitely put everything central. But, when considering your garage as a location, think about heat. If equipment gets too hot, it will shutdown or malfunction. You are using some decent equipment. But ProCurve gear is pretty serious for home. Not a bad thing, but I a wondering why you need 2x24 port switches? How many devices will you have? And on top of this, a separate POE switch? Personally, I would be looking at getting a single 24 port switch (or 48 if you really need it) with POE built in, and on all ports. 3 switches in a home environment is not over excessive, it is messy. Ubiquity definitely is the way to go. Well priced and robust. If you really need to use enterprise level gear, I would use this - http://www.ebay.com.au/itm/Cisco-WS-C37 ... Sw5ZBWIyJL What sort of cable did they wire your house with? Cat5e, Cat6, Cat6a? Re: Network Confusion.. Need Help!! 10Jan 13, 2016 1:24 am Run all CAT6 cable throughout the house regardless of what you intend to use each point for - flexibility and expandability is the whole point of "smart" wiring. It may be more suitable to have it beside the NBN NTD, though not essential. If I were to have any reason to have the hub located separately, I would put it upstairs and not under a staircase. NVR location - either can work, but moving to garage makes sense. Another option is and as hinted before - If you chose to have it more of a centralized setup, you could do away with a POE NVR and run all your data points and cameras off a POE Switch, which would allow you to run a quieter NVR in perhaps a theatre room, one of my clients has a big screen for his cameras and he can flick through it with his remote control whenever he wants to playback anything. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Network Confusion.. Need Help!! 11Jan 31, 2016 12:10 pm Here is a rundown of mine with data points and tv points combined. http://i1033.photobucket.com/albums/a418/Aussie141414/Untitled.png Re: Network Confusion.. Need Help!! 12Feb 14, 2016 10:00 am Roomeat We are also going to add 2extra data points into the ceiling (1 upstairs and 1 downstairs) to be able to install a ceiling mounted WAP on each floor. Can anyone recommend a good product? I am coming in late here, but would recommend the Ubiquiti Unifi access points. I've used their new UAP-AC-Lite, perfect for residential environment and coupled that to an EdgeRouter PoE, which is a 5 port switch. One to the network, two for the access points plus (it provides the power they need) plus two for local equipment. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8508 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6554 Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23839 |
