Browse Forums Owner Builder Forum 1 Dec 09, 2015 10:14 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 2Dec 09, 2015 10:44 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 3Dec 09, 2015 10:55 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 4Dec 09, 2015 11:00 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 5Dec 09, 2015 11:07 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 6Dec 09, 2015 11:34 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 7Dec 09, 2015 11:57 pm = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 8Dec 10, 2015 12:08 am = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 9Dec 10, 2015 12:23 am Roof trusses were installed 9th of October. Filled up the pool in the meantime as advised by the pool co straight from the front tap with a hose. Contrary to what most people would think (including me), it only cost around $100 to fill up which took about 15 hours all up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 10Dec 10, 2015 12:39 am After looking around for months, we finally sourced these beautiful ironbark timbers from a yard in Kingslake. The seller actually got caught up in the Black Saturday fires back in 2009 but thankfully survived without too much damage. (Posts are not from fire damaged areas). The larger 300mm x 300mm post is more than a century old and was removed from Melbourne Pier near Docklands and has some beautiful character to it, while the other 3 posts are 250mm x 180mm were used in a NSW railway and contain some original plate marks. These are all structural and A grade timbers, with the larger post weighing around 300kg. The larger timber will be a corner post where the 2 stacker doors meet, creating a stunning centre piece. I chiselled out a channel where one of the stacker doors will be mounted so we can run electrical cables for lighting and have a modern switch plate to create an old&new look, while the other smaller timbers will be on the other end of the stackers each while the last one will be on the corner in our master bedroom. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 12Dec 10, 2015 10:31 am Sloppy That's a good design for a narrow block. What part of Australia are you in? Thanks. We're in the Hume municipality, Victoria. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 14Dec 10, 2015 11:37 am We're almost at plaster stage now but will keep posting progress photos soon. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 16Dec 16, 2015 9:19 am Posting to follow. Youve achieved alot of progress in a short period of time. Looking great. Keep the updates coming! Build thread: viewtopic.php?f=38&t=75302 Re: OB in Hume area - VIC. Fast forwarded + photo heavy 17Dec 27, 2015 2:16 pm Time for some more photos View from the master bedroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ From the rear of the house Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ From the side Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 18Dec 27, 2015 2:23 pm Sisalation time Pool side with the not-so-tempting smurky green pool = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy 19Dec 27, 2015 2:37 pm Here's the finished look of our feature reclaimed timber post, measuring 300mm x 300mm and weighing a whopping 300kg which took 6 of us to install. I chiselled out a channel on the stacker door side making room for electrical cables so we can mount a light switch on the lounge side. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: OB in Hume area - VIC. Fast forwarded + photo heavy - TI 20Dec 27, 2015 2:45 pm We also installed box heads so we can install hidden curtain tracks along the windows where blinds are going to go.. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5640 What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12402 |
